hey guys,
well the track has been closed for a couple months now and I'm not real impressed with my times so far.
I have the following mods: AFR165s, cobra intake, 11:1 compression (from a fresh rebuild), x303 cam, prom 77mm MAF, 30lb injectors (big i know, but i needed new ones right away), fuel pressure regulator (to lean out the big injectors a little bit), 65mm TB, and 3.73s with ET streets.
My best time so far has been a 13.4@100 mph. The track here is about 4800 feet above sea level and has been known to be a crappy track, but I would still like to have a better mph. I know my car is a pretty heavy sob since I ran it like I drive it to work.
I don’t have a lot of money to drop into it this summer thanks to college, but here's what I'm thinking:
Ditch the C-springs (wanted a nimble ride, but that’s changed). I figured this would help with my crappy 1.8-1.9 60s. Any suggestions as far as a streetable "drag" coil?
Go with an Ed cam, figured the x303 is hurting me and not giving my combo all it’s got.
Get a performer RPM to replace the cobra intake (anyone have any comment on that)?
Those are the main things that I know I'll be able to afford. If you guys have any suggestions for me please let me know. I am barely able to beat my buddy's GN with a few mods and 20psi, I really want to beat him this summer.
Forgot to mention my driving style: I launch at around 4k, any more and it seems to spin even if I heat the tires up a bit. I've tried shifting anywhere from 6k-7k (read off my autometer gauge with rev limiter removed through EEC tuner) and it doesn't seem to make much of a difference. I consider myself a decently fast shifter, especially the 1-2 shift, no power shifting however. I cross the line just getting into 4th (which probably is killing some mph) since I don’t know if I want to take it above 7k.
Sorry if this isn't too coherent, 14hours of studying for finals will do that to a person.
*on edit* I forgot to mention I have 1 5/8's bbk full lenght headers into 2.5" exhaust (h-pipe) and flow master 2 chamber mufflers (no cats).
