Help me set up and decide on my 347 combo
  • Thread starter Thread starter Grn92LX
  • Start date Start date Oct 17, 2004
  • 3
First Prev 2 of 3 Next Last
SlowGT
826
Columbia Co, PA
Oct 17, 2004
#21
  • Oct 17, 2004
  • #21
I think the 1262 is what I've got for between my R-lower & AFR 225's. The AFR intake ports are 1.4 x 2.25, but I'm going to try it without opening up the intake. 225's might be too much for a N/A 408 ...may end up with the Dart 210's. Time will tell.
Grn92LX
Fidanza Man!
6,819
64
129
New York
Oct 18, 2004
#22
  • Oct 18, 2004
  • #22
Thanks a lot Thomas! Thats exactly what I needed to see. Could you post a shot with the 1262 gasket when you get it? What did trickflow mean when they said ' port size at mating flange 2.38 x 1.38'?? What the fugg is the mating flange??Looks like that R lower is a perfect match to TW heads. If the gasket protrudes in the port a little, you could always cut it with a razor. Don't forget to cut out the coolant port on the gasket since it blocks the coolant port as you can see.
Rick 91GT
Mustang Master
95
99
PA
Oct 18, 2004
#23
  • Oct 18, 2004
  • #23
Cast internals are fine, they will last a lot longer then the stock block will, although I prefer the SCAT cast stuff to the Eagle.
I'd go RPM II the R is a little too much intake IMO for what your planning, stocker or not. I think the RPM II will provide you a better torque curve and make it more usable in your rpm range, your limited by the stock rev limiter. I'd suggest a 38#-42# injector (42# preferrably) and use some type of tuner, PMS would be a good choice. I datalogged my 30# with only 340RWHP and they were over 80% duty cycle.
Ed's right, gasket matching is a joke not worth the time or money, the gains are very minimal. You can not tell how good the ports are going to match by looking at someone elses photo's, the intake needs to be mocked up on YOUR OWN block for accurate readings. Decking the heads and or block changes things a good bit.
I'd give Ed or Jay a call, both will get you to your goal. There is no reason with some head and intake porting you can not reach 425RWHP, NA.
SLOWGT The 225's will be perfect on top of the 408, just don't starve the heads.
90MustangGT Almost any stroker crank can be balanced at 50oz, it just isn't the preferred method since a lot of material has to be removed. You can have the crank weights turned to remove the weight instead of making the crank a piece of swiss cheese, most good machine shops can do that for you. If you are planning on a forged internals motor the new Eagle internal balance cranks are very nice and will go "0" for the same prices as most 28oz balance jobs.
Thomas302
119
Alamogordo, NM
Oct 18, 2004
#24
  • Oct 18, 2004
  • #24
My 1262 should be here tomorrow, I will take a pic. Sorry the pics are a little blurry, I was trying to get close. I think trickflow means that it is 2.38x1.38 were the upper meets the lower, because on my intake, it is bigger there then it is where the lower meets the head. Its a nice intake. I will let you know how it works, I am probably going to step up to 4.10 gears to get some more low end, but I should make up way more on the top over my Gt-40 then I lose on the bottom. I shall see soon. Hope this helps.
SlowGT
826
Columbia Co, PA
Oct 18, 2004
#25
  • Oct 18, 2004
  • #25
I thought so too when I bought them, but it's taking me so long to get everything together that I've been having time to second guess. Thanks for the vote of confidence Rick. I'm topping them with an TFS-R lower and a Reichard's box upper. Feeding with an 80mm TB and an 80mm MAF meter. Looking for around 630-650 fwhp.
Rick 91GT
Mustang Master
95
99
PA
Oct 18, 2004
#26
  • Oct 18, 2004
  • #26
Nice combo what size header are you going to use? 1.875" ?
I'm partial to those AFR 225's for some reason
Grn92LX
Fidanza Man!
6,819
64
129
New York
Oct 18, 2004
#27
  • Oct 18, 2004
  • #27
Yes, that makes sense. It looks like the R lower is a near perfect match to my TW head which is good. I do like the trickflow stuff and I like keeping it all one brand. I emailed Jay again to see exactly what he thinks for an intake for my car. I am pretty set on the R and i've seen them for like $490 which IMO is a killer price. Fox lake has it for $479 and I will see if summit will price match it.
What kind of port work should I be looking to have done?
Jay told me the 1 3/4" header is a must.
Any other comments?
Rick 91GT
Mustang Master
95
99
PA
Oct 18, 2004
#28
  • Oct 18, 2004
  • #28
If you are working with Jay for the cam then use his reccomendations..... it will allow the cam to bring out the full potential.
I agree on the headers.....
SlowGT
826
Columbia Co, PA
Oct 18, 2004
#29
  • Oct 18, 2004
  • #29
Yep. Kooks. I must be the slowest in the world. I took the car off the road last July (2003) and it still isn't together. The worst part is, I've got everything I need except the TB and driveshaft. Been waiting to find a deal on the TB and I can't measure for the driveshaft with the rearend & transmission out of the car. I've pretty much given up on any track time with it this year. Maybe I can get in done and tuned by Bradenton.
Rick 91GT
Mustang Master
95
99
PA
Oct 18, 2004
#30
  • Oct 18, 2004
  • #30
My car has been apart since October 2002, started off just building a new 408" street motor, then decided to gear it more towards a NMRA Drag Radial combo.
Built the 408, switched heads and cam before it even ran, switched from EFI to carb, agian before it ran..Sold it all. Started concentrating more on a NMRA set-up, race block, billet crank, etc.. small cube N2O motor, then after seeing the N2O motors not competing sold off the N2O stuff and got a big ole Procharger.
Oh, and my car is almost a 25.5 SFI cert'd chassis car, should be out for next season if all goes right.
Started off build a high 8 sec, low 9 sec car, now I am gearing towards 8.0's.
SlowGT
826
Columbia Co, PA
Oct 18, 2004
#31
  • Oct 18, 2004
  • #31
Rick 91GT said:
My car has been apart since October 2002...
Glad to see I'm not the only one. My initial goal was 11's on street tires (not DR's or cheaters). Then somebody told me that I'd fit into DR...if I wanted to switch to an auto. So now I guess it's just going to be a crazy street car. The only thing left to play in is Wild Street...and I can only hope for a lucky break to be the 'King'. Most of the winners this year were in the 9's with a few in the 8's
Grn92LX
Fidanza Man!
6,819
64
129
New York
Oct 19, 2004
#32
  • Oct 19, 2004
  • #32
Yeah Rick, I am going with jay for a cam. I will use what he says is needed. I did tell him I wont use a victor intake since it doesn't have egr ports on it though.
I emailed AFM and they told me the N81 with a Holley intake will work good for me. I think Jay is my best bet.
Mike
Grn92LX
Fidanza Man!
6,819
64
129
New York
Oct 20, 2004
#33
  • Oct 20, 2004
  • #33
After talking with Jay I am dead set on the TFS R. He told me the holley would make the low end I want, but he recommended I build the engine to make power. He mentioned being able to down shift to second when a zo6 or something pulls up and pull away from it and he said that would be how the R will kill the holley. He said I should also take it to 6500 when needed which I will do. Now I just need to know what he thinks if I should have my heads ported or not. I emailed mike curcio race products in pennsylvania. He gave me some nice prices and said he could get them to flow 285/210.
I did also see a graph of an afm N91 cam, afr 185 heads and a holley intake. car made 416hp/408 tq. The curves were good to and the low end was decent for that 'hi rev' cam. It peaked at like 5800 and then went down.
Rick 91GT
Mustang Master
95
99
PA
Oct 20, 2004
#34
  • Oct 20, 2004
  • #34
Mike and Joe @ MCRP are good smart guys that will get you moving, they will work close with Jay to get the car running great based on the cam....
I saw similar results with the AFM cam, once it peaked the power steadily dropped off. I have seen other custom cams that peak and hold the power much longer.
So are you going to buy a PMS so you can raise the rev limiter?
Thomas302
119
Alamogordo, NM
Oct 20, 2004
#35
  • Oct 20, 2004
  • #35
How much torque do you think the R is down on the Holley through the power band and up on Hp. I have seen the numbers on a few dyno graphs on the R and it make good tq from 2500 on up but I have never seen the holley dyno. Example, If the R is down say 10fps of torque through the power band, but up 20hp, that would be a good trade, but if its the oposite( down 20tq and up only 10hp, that would not be a good trade right? I have a motorsport extender so I dont have to worrie about the limiter, and my cam will make good power to at least 6300 and peak about 6100 if I dont have valve float. I think I will be okay with the 4.10. Just trying to get all the info I can. Sounds like you have done some good homework, not like me were 2 years ago I build this motor, and now I am trying to change it for more power because I did no homework back then.
Grn92LX
Fidanza Man!
6,819
64
129
New York
Oct 20, 2004
#36
  • Oct 20, 2004
  • #36
I do not know how much you'd be giving up down low. I would guess you*might* give up a little torque below 2500, but I just dont think its enough to worry about. I think with the extra iches and more compression I will still make much more tq down low than my 302 does even with the 'big' R intake.
Can you show me those R graphs you saw?
Rick, no I dont plan on buying a pms. That tuning stuff is a bit over my head, though, if I found a used one at a good price I would consider it. I would be asking guys like yourself millions of questions though If not, I would try another chip or buy a used fms extender.
R
RIXX93GT
166
Dayton, Ohio
Oct 20, 2004
#37
  • Oct 20, 2004
  • #37
Why such big injectors? I just got back from my first dyno pull, untuned with pig rich a/f ratio made 320rwhp, 359 tq. Theres lots more in it.The a/f never got above 11.5 with 24's and 40 psi fuel pressure vac off.
I am not trying to be a critic just trying to learn.
Grn92LX
Fidanza Man!
6,819
64
129
New York
Oct 20, 2004
#38
  • Oct 20, 2004
  • #38
Here is a 347 graph I have on my computer of ported afr 185's by neil erickson, TFS R intake 1 3/4" longtubes and a comp cams custom solid roller. This thing makes lots of torque down low.
http://www.mustangcentral.net/neil/customers/jeff/jeff347.jpg
Red line is a nitrous pull and blue is n/a pull.
Rick 91GT
Mustang Master
95
99
PA
Oct 20, 2004
#39
  • Oct 20, 2004
  • #39
HOw high were you reving it?
I datalogged my 30# with only 340RWHP @ 6600rpm and they were over 80% duty cycle, saw 36# at close to 75% duty cylce making 420RWHP. It really depends on the entire combo, and the cam has a lot to do with it.
R
RIXX93GT
166
Dayton, Ohio
Oct 21, 2004
#40
  • Oct 21, 2004
  • #40
I was only revving to 6000, I do have a cam that was designed to be emissions legal
  • 3
Engine An engine building combo with stock Speed Density (SD) system
  • Mcmahst
  • Jan 14, 2025
Fox 5.0 Mustang Tech Jan 15, 2025
Mcmahst
F
Ford 460 swap
  • Ford460
  • Sep 13, 2026
Ford460
F
  • 68_Disgustang
  • Feb 22, 2026
1965 - 1973 Classic Mustangs -General/Talk- Jun 20, 2026
gray owl
G
C
Engine Can change - valve springs also?
  • Cg’s 347
  • Feb 17, 2024
2K
Fox 5.0 Mustang Tech Feb 22, 2024
2000xp8
Progress Thread BluePrint 347 long block engine swap
  • Sparky714
  • Aug 2, 2024
  • 7 8 9
11K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- May 8, 2026
Sparky714
