when i push my clutch in almost immediately i can hear a grinding sound, definitely moving in a circular motion. and my clutch (king cobra) seems to be a bit heavier, only when the car is on. Im pretty sure i got some salt or sand into the bell housing and it probably did something to my throwout bearing. all i have to do is put a little bit of pressure on the clutch pedal and you can hear the throwout bearing (at least i pretty sure its that) spin as if there was no grease in it any longer.
if it is the throwout bearing, is there any way i can put grease into it or around it without dropping the tranny? i was thinking i could probably do it where the clutch cable connects to the (forgot the name of that part the cable connects to on the tranny.) transmission. maybe by taking that little cover off and reach a grease gun into there?
