Hey guys. whats the best way to figure and calculate what injector size I'll need?? I can give motor specs if needed....
Thanks
---Ryan
Thanks
---Ryan
Just tell us what your engine setup is and we will tell you what to use.
No reason to over complicate something so simple
Sounds good, I'm slow when it comes to calculations::
Stock bore 302, Factory Crank and rods with Forged Aluminum Pistons (factory dish), Ported E6 heads, X303, 1.6 alum roller rockers, Gt40 intake, 70mm TB, bigger MAF (haven't bought yet obvisouly), and I'll be running a wet kit.... I'm assuming somewhere close to 100shot. I also have an Aeromotive Adj Fuel Press Reg so I can play with my pressure. I had it set to 42psi before motor went down for rebuild.... I think I've got everything in there.
Thanks for the help guys.
--Ryan
Assuming you have a headers-back exhaust, your 302 will be putting out roughly 320-325 flywheel HP (all motor) so you'll need 24lb injectors.
Money is tight, but I can get it if I need it, and after readin y'alls replies, I started lookin into the AFR 165s and the TFTW heads... You think they would be a good head for my setup?? I just spent the money on the forged alum pistons and don't wanna have to send them back and spend more for bigger notched pistons if I don't have to, but I still wanna make this $3k build worth the time and effort on the fun-o-meter. I'm aiming for mid to low 11s on spray
--Ryan
