help me with this 2.3L question
(This follows a question I asked the other day)
I recently bought a $200 89 mustang with a 2.3L and a 5 speed. In the local salvage yard they have two Merkurs and a turbo coupe (all 88's I believe), all 2.3 L turbos. answer this for me please;
1) How do I check and verify that the turbo, or the motor itself, from any of these cars are good in a yard?
2) What would I need (give me a parts list) to put the 2.3 L turbo from one of these cars in this mustang nothcback. I am looking for a complete parts list, besides the obvious motor and exhaust work. Is this a different ECU as well?
I just did the same swap you are inqiring about. My car is a 85 but the entire electrical system is from an 89 Mustang. I have a complete parts list on my site you can look over. It's specific to the 89 Mustang and and 88 TC as the donor.
Flemworld
Click on the Slugstang Section and then the How To's section.
There are also 4 other sites you can check out that aided me in my swap.
140CILX = http://140cilx.stangnet.com/
CROVAX = http://heavymetal.stangnet.com/
GT350r = http://gt350r.stangnet.com/index.html
Stinger = http://24.91.96.177/stinger/
As for checking the motors I would say compression check.
As for the Turbo's a visual inspection of the turbo fins and check for shaft play and rubbing.
:stupid: very few things you can do to determine if its a worthy motor. all i did was take out the plugs , with a flash light looked to see what i could see in the cylinders. Took a rachet and manually turned the crank to make sure it was not siezed. The best thing in my book is too look for obvious reasons that that specific car is there, like collision damage of some sort. You have more reason to believe that car was *atleast* running at the time it was totalled and sent there. Also look for a very clean car, nice (not shreded) interior and a really clean body, alteast that car may have be taken care of...either exstreme usually catches my eye :nice:
