Help my buget build
  • Thread starter Thread starter Ramsey 93
  • Start date Start date Aug 27, 2008
Ramsey 93
15
  • Aug 27, 2008
I am trying to get around 300 rwhp off spray, I already have longtubes, catless h, mac dumps, trick flow track heat upper and lower with 1 spacer, bbk fendor mount, bbk pullys, cf dual friction, 3.73s.
I am looking to put heads /cam/ push rods/lifters/ springs and retainers next.
I have seen heads as cheap as 200 bucks, and cam/ push rods/lifters/ springs and retainers packages for 250.
Can you recomend what items i should be looking for? what to stay away from?
I dont want to fly cut the pistons or change headers. I reaslly want to stay under 800 bucks, is that possible?
Oh and i have a full wet kit to put me around 400 after 300 n/a mark
Edit: i have a walboro 255
NKau
1,346
Jefferson, WI
Aug 27, 2008
  • Aug 27, 2008
Your best bang for the buck at this point is going to be heads. A cam doesn't buy you anything with stock heads, and doesn't buy you a ton, even with heads and intake. You already have a good intake, so I'd be looking to scoop up some cheap GT40P's (not all headers fit these due to spark plug angle), or even some Edelbrocks/Trick Flow TW's if you can find them used and cheap. Just be aware that refreshing used heads and buying gaskets necessary for the swap will cost a little as well. Might want to look at upgrading your fuel pump, MAF and injectors as well assuming you haven't; I would think adding heads along with nitrous on top of that is going to have you running into some fuel issues.
Ramsey 93
15
  • Aug 27, 2008
I i have a walboro.. i assumed i would get injectors and maf according to what my duty cycle looked like on the dyno. Also, i wanted to the full top end to save on install time. thanks for info so far.
what kind of power are you making? any track times?
G
Engine Pushrod Length Question
  • germain101
  • Sep 22, 2025
Fox 5.0 Mustang Tech Sep 25, 2025
D
N/A build on fresh stock 302
  • djcarrot
  • Oct 14, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 19, 2026
AeroCoupe
9
Engine Donor '00 Mountaineer meet '91 Fox
  • 91firecracker
  • May 11, 2026
  • 2 3
Fox 5.0 Mustang Tech May 28, 2026
91firecracker
9
M
Pushrod length
  • mattcrp1
  • Sep 1, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 4, 2025
mattcrp1
M
C
347 advice
  • CRonaldo773
  • Jan 27, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jan 28, 2026
2000xp8
