help need some info
1994mustang5.0
hello i have a 1994 mustang 5.0 5 speed im thinking about a 400 engine in it from a older ford truck i need some tranny info some bolt in info and some general info about the build is it worth it should i do it will it work ? any info will be greatly appreciated because the dude is about to get rid of the engine:shrug:
First off welcome to stanget! For us to really be able to help you, we will need to know what you want out of your car and what kind of budget you are working with. Also tell us what the current situation is with your car as far as condition, miles, motor. As far as motors go there is the most support for 302 based motors, the next best would be for the 351w (which can be stroked to well over 400 ci). There are a lot of very helpful existing threads on here that can be found using the search function. I suggest doing a ton of searches and a ton of reading. Good luck on your searches and let us know if there are any other questions you may have!
you could probably make that 400 work but you'll probably be blazing your own trail on that one. 302 and 351s are common and have the support of the aftermarket. I'd agree with Shaun though. we need to know more about your car now and your hopes for the future before really being able to help you out.
