I posted this in the Fox specific forum, but no luck there
so I decided to put it in here.
A few days ago, I got on the car pretty good. I was doing a 2nd gear dry burnout to be more specific. Shortly after that, I began smelling something like a burning odor. I had had a leaf get caught in my headers a while back and was thinking that it might just be that again. Well, several members of my club and I drove up to Tanglewood for the Festival Of Lights. We waited in line like 2 hours to get in and I smelled the odor periodocly. We get half way through the park and pull over at a restroom/concesion place. I go to start my car back and nothing happened. It tried to turn over and everything, but just wouldn't spin over. Acted exactly like a dead battery.
Well, I get security to come out with a jumper box and jumped me off. Car ran fine after that, but I noticed on the way home that I was running like 10 volts max.
This has happened to me before. About a year ago, I sarted smelling a burning odor and had problems starting the car. I replaced the alt (90A) and the batery, just to come to find out that the negative battery cable was shorting out. Well, I looked at the cable this time. The main cable is fine, but that smaller gauge cable that ties into the neg cable apears to be shorting out. I haven't tracked it back to the place of origin yet, but I believe it is in there with the coil and starter relay somewhere.
Anyways, do any of you have any idea why I would be shorting this out? And why did it do it when I was romping on it pretty good? I am normally able to figure out almost any car issue, but this one has me stumped. ???
OK, I have posted this at a couple different places. here are some of the responses I have received:
1-Coil problem
2-starter bolt (??)
3-weak or cracked engine mount
4-ECM groud wire
5-alternator wiring
The guy who posted up the #4 response also posted this quote from the ProFlow website:
"Check the computer ground wire on the negative battery. Disconnect the negative terminal from the battery and find the small black wire and measure the resistance. The value should be 0.2 ohms or less. If this measurement is above 0.2 ohms, then add an additional 10-gauge wire to the negative battery terminal to the frame connector. Run self-test again. When you relocate the battery to the trunk, most people chop the wire from the negative terminal to the frame, and ground the battery using a short cable to the frame rail in the trunk. This will cause the vehicle to run lean and very erratic due to poor grounding of the electrical system and ECM ground. Using a welding cable, connect the battery negative terminal to the engine in the same place it was connected before the move. Use a second 10- gauge wire from the battery negative terminal to the frame connector (near the washer bottle for 88-94 models. On newer models follow the old wire from the negative terminal to the frame.) It must be restored."
What do you all think!!?? I really don't want to have this happen again. It's pissin' me off!!!!
so I decided to put it in here.A few days ago, I got on the car pretty good. I was doing a 2nd gear dry burnout to be more specific. Shortly after that, I began smelling something like a burning odor. I had had a leaf get caught in my headers a while back and was thinking that it might just be that again. Well, several members of my club and I drove up to Tanglewood for the Festival Of Lights. We waited in line like 2 hours to get in and I smelled the odor periodocly. We get half way through the park and pull over at a restroom/concesion place. I go to start my car back and nothing happened. It tried to turn over and everything, but just wouldn't spin over. Acted exactly like a dead battery.
1-Coil problem
2-starter bolt (??)
4-ECM groud wire
5-alternator wiring
