Help needed
Foxbody_1990
15
The south
Hello fellow foxbody owners, so I need to some help and answers. Recently purchased a coupe that has a fresh paint and perfect interior so obviously I gotta do a coyote swap lol so I purchased a junkyard 2013 5.0 this past week and have already purchased a couple things. Bought a 13 gt intake and my first question is will 302 boss camshafts fit this engine and heads? Gonna be tuned at the end of this build anyways. Second questions, would you guys recommend the ford wiring pack of the Holley? Which is better and what are the advantages of each?
  • Sponsors(?)
90sickfox
I didn't really have an issue with the stink...
SN Certified Technician
Mar 2, 2015
5,174
4,264
203
42
No idea...but I'd use the Ford control pack....because....Ford.
Mustang5L5
i'm familiar with penetration
Mod Dude
Feb 18, 2001
33,310
9,610
224
Massachusetts
The ford pack will get you up and running and run a stock coyote very well since it's practically an OEM system. The Holley pack will give you greater flexibility for tuning for modified setups with cams and forced induction and such. Which do you need more?
Yes, the 302 BOSS cams will fit the Gen 1 heads on the F150. It's a very common swap to grab an F150 motor, and swap to GT or Boss cams and a '15, or 18'+ Mustang intake. Your compression will be a tiny bit lower however vs a Mustang motor, but great for forced induction.
Foxbody_1990
15
The south
Ok great, was gonna pick me up a set of those cams for sure, so my understand is the Holley setup is just for running purposes and won’t actually run the car as the ford pack would? Sorry for the bone head questions.
Foxbody_1990
15
The south
Also which control pack do I need?
Mustang5L5
Mod Dude
Feb 18, 2001
33,310
9,610
224
Massachusetts
Fuel level sensor would be separate. That wiring would be between the guage and sender.
the Ford and PBHkit both use ford ECU but the pbh has a custom flash and some additional wiring.
Foxbody_1990
15
The south
Which would you use or have you used either? As far as the starter and alternator goes can I just buy a oem from let’s say rock auto and use those? For the brackets what would you use for those?
Mustang5L5
Mod Dude
Feb 18, 2001
33,310
9,610
224
Massachusetts
if I were doing it with a Gen 1 truck motor and manual trans, I’d run this kit by PBH.
however, according to the listing there are some mods to make to use it with the F150 motor.
Foxbody_1990
15
The south
It mentions custom calibration but I had already had intentions on having this tuned, you think that’s what they mean? I’ll give this bunch a call tomorrow and make sure. I’ve seen YouTube channels where they buy the ford pack and nothing extra as far as mods are made.
Thread starter Similar threads Forum Replies Date
D Suspension Griggs rear set up on my 1991 GT, need help with set-up Fox 5.0 Mustang Tech 1
mustangpauly 351w swap need help will not idle Digital Self-tuning Forum 8
T Need help identifying casting numbers 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 7
ameration Need Help with new 5.0 Purchase 1994 - 1995 Specific Tech 6
J Need help with qurterhorse and running Digital Self-tuning Forum 1
L Electrical Need Help Fox 5.0 Mustang Tech 15
B Need some help cars not right SN95 V6 Mustang Tech 1
T need help deciding on what cam i should get for my mexican block 302 Fox 5.0 Mustang Tech 8
A Engine 87 EFI 5.0 to my 83 four eye need help with wiring Fox Engine Swaparoo 0
R Need help finding reverse switch on transmission Fox 5.0 Mustang Tech 5
S CARWASH WASHOUT NEED HELP PLEASE 1996 - 2004 SN95 Mustang -General/Talk- 3
C Need help troubleshooting p1233 code. SN95 4.6L Mustang Tech 2
7991LXnSHO VW OBD2 help needed. Other Auto Tech 0
8 Engine Need help Fox 5.0 Mustang Tech 6
B Engine 1990 5.0L Fox high rpm cutout and loud backfire - Need Help Fox 5.0 Mustang Tech 11
silverlx50 Engine Bringing Charcoal Canister Back, Need Help Fox 5.0 Mustang Tech 4
A Drivetrain I Need Some Flywheel help/knowledge please Fox 5.0 Mustang Tech 7
B Need Help 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 2
YadiStang 1969 mustang. Need help with door lock actuator rod 1965 - 1973 Classic Mustangs -General/Talk- 0
D Brake issues I need help figuring out what part to order 2005 - 2009 Specific Tech 1
M I need help sourcing/repairing a fender 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 7
D Progress Thread 2003 mustang gt Rebuild 1996 - 2004 SN95 Mustang -General/Talk- 10
S Electrical Need help with unidentified wire connector on 4 cylinder LX 2.3L (N/A & Turbo) Tech 3
F I need some help SN95 4.6L Mustang Tech 1
W T5 rebuild - need help identifying parts Fox 5.0 Mustang Tech 12
Gman007 Need help with strut choice. SVT Tech Forum 8
markinms Engine Explorer Intake Swap Performance Issues - Need Help! Fox 5.0 Mustang Tech 10
S 2002 gt need help. 1996 - 2004 SN95 Mustang -General/Talk- 4
T Need help with throttle cable. 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 1
T Engine Need help with 5.0 ho speed density build Fox 5.0 Mustang Tech 9
S 1995 Ford Mustang 3.8L V6 - Electrical Issues - Need Help! 1994 - 1995 Specific Tech 8
T Questions about power steering delete!! Need help!! 1996 - 2004 SN95 Mustang -General/Talk- 5
R need helpful tech help Fox 5.0 Mustang Tech 3
D Need sct x4 users help please. Digital Self-tuning Forum 0
E I need help with my AC system 1996 - 2004 SN95 Mustang -General/Talk- 5
G Engine Need help with cooling system issue Fox 5.0 Mustang Tech 12
N Need Help w Heater Blower Failure 1994 - 1995 Specific Tech 13
Jetzv8 2014 Mustang radio not working. NEED HELP Mustang Sound & Shine All 0
A Suspension Fox steering rack leaking need help Fox 5.0 Mustang Tech 1
S PWM Fan controller - Need help/clarity on a purchase 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 32
F I need help Fox 5.0 Mustang Tech 1
lamrith New MSPnP2 in 94 Mustang, need help getting stable idle once warmed up. Digital Self-tuning Forum 1
W 347 Header Size and exhaust Diameter 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 51
Z I need help with pistons 1996 - 2004 SN95 Mustang -General/Talk- 1
trlps_ Need help, car wont rev up or drive 1996 - 2004 SN95 Mustang -General/Talk- 2
T Electrical Need help with A/C clutch cycling connector Fox 5.0 Mustang Tech 2
bmgstang Need help with tune high idle Digital Self-tuning Forum 7
S Engine Need help: heater hose routing for 92 2.3 liter 2.3L (N/A & Turbo) Tech 4
T First fox... she needs help. 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 42
C Engine Help diagnosing a whine at low gas pedal pressures - 1998gt SN95 4.6L Mustang Tech 2
