every thing is pretty much off of the engine...my heads are off, intakes, distributor, wiring..etc.
NOW i need to clean the pistons and the crud out of the cyl WHILE the pistons are in the position they are. what do i use.and how do i do it..AND VERY IMPORTANT QUESTION> HOW are the pistons and the cylinder itself suppose to be RIGHT BEFORE the heads go on.fluid wise....what should wipe it out with..what should i coat it with..i need to know what is suppose to be in there?
ALSO...Is it a good idea to suck out the water ports in the block where all the antifreeze is with a vacuum??it seems like a pretty good idea..figuring soem crap also fell into there...
that **** doesnt need to be in there right
