help please 93 gt sti plug
Dumping The computer diagnostic codes on 86-95 Mustangs
Revised 19-May-2009 to update drawing for dumping the codes on 86-88 Mustangs with no check engine light.
Dump the codes and see what the computer says is wrong…Codes may be present in the computer even if the Check Engine light isn’t on.
Here's the way to dump the computer codes with only a jumper wire or paper clip and the check engine light, or test light or voltmeter. I’ve used it for years, and it works great. You watch the flashing test lamp or Check Engine Light and count the flashes.
Be sure to turn off the A/C, and put the transmission in neutral when dumping the codes. Fail to do this and you will generate a code 67 and not be able to dump the Engine Running codes.
Dumping the Engine Running codes: The procedure is the same, you start the engine with the test jumper in place. Be sure the A/C is off and the transmission is in neutral. You'll get an 11, then a 4 and the engine will speed up to do the EGR test. After the engine speed decreases back to idle, it will dump the engine running codes.
Here's the link to dump the computer codes with only a jumper wire or paper clip and the check engine light, or test light or voltmeter. I’ve used it for years, and it works great. You watch the flashing test lamp or Check Engine Light and count the flashes.
See Troublcodes.net Trouble Codes OBD & OBD2 Trouble Codes and Technical info & Tool Store. By BAT Auto Technical
attachment.php
attachment.php
What to expect:
You should get a code 11 (two single flashes in succession). This says that the computer's internal workings are OK, and that the wiring to put the computer into diagnostic mode is good. No code 11 and you have some wiring problems.
Alternate methods:
For those who are intimidated by all the wires & connections, see Actron® for what a typical hand scanner looks like. Normal retail price is about $30 or so at AutoZone or Wal-Mart.
Or for a nicer scanner see Digital Ford Code Reader (3145) – It has a 3 digit LCD display so that you don’t have to count flashes or beeps.. Cost is $30.
i still need help with my sti. they only wires i have are(using the number lay out on the test plug on the following link.
http://www.muscularmustangs.com/eec2.gif
1 white/purple
2 grey/red
3 empty (has grey plastic connector for sti but no wire)
4 white/green
5 empty
6 2 blue/orange wires
(says international models have the sti in port number 5 but i dont have a wire in port 5)
. i opened up the wiring and i still cant find it
Ford Fuel Injection » How To Run a Self-Test
http://www.veryuseful.com/mustang/te...ainHarness.gif
number 30shows both , but it only lists 5 wires and i have all of them
http://www.veryuseful.com/mustang/te...ng_Diagram.gif
do 92 and 93s not have one, on the link above its says vip connector 91 only and this is the same diagraam as my haynes. is the vip the same as the sti?
NO self test input "STI" - Mustang Forums at StangNet
maybe im not the only one.
could someone (with a 92 93 gt) please look at there car for me, i undid the wireharness all the way to the passenger side firewall and it is no where to be found
thats what i was thinking, my buddy came over with his 89 lx but the wiring is different. could i blow the ecu if i try jumping that wire to run codes? we figured it was that wire also but didnt want to try it in case it would wreck the computer.that you for the help. but if any one has a 93 could you please snap a pic of your wiring for me please. thanks
