Help please!!! Coolant crossover 4.6 4v
petemakmt
Mississippi
I recently purchased a 96 mustang cobra and I noticed that my coolant crossover tube is very rusty on the outside as well as inside. Its very hard to find a crossover tube replacement so Ive been looking at a delete kit instead. A bit pricey, but my question is I see all these kits change the t stat housing to the upper radiator hose. I was wondering what happens to the lower radiator hose??? The pictures I see theyre just gone. Is it okay just to plug it up or what do you do with it?? Any help is appreciated.
For most of the ones I've seen, moving the thermostat up top is optional. You should be able to run a Y into the upper radiator without the thermostat.
Alternatively, if you did want to remove the thermostat from below, you could swap the oil cooler for a 2V version and run a 2V lower hose (which doesn't have all that).
I have one I just took off my 98 cobra. Its in perfect condition if you are interested. Text me if you are. 5702448302
