help please
Guero
2,148
wew rented a harmonic balancer puller, but its ****ing hard as ****. is that normal? or is there any how to for the removal. were trying to get to the cam
did you remove the crank bolt and washer before installing the tool?
what are you using? a breaker bar or impact gun?
sometimes when you have the puller installed, give the tool a few smacks with a hammer on the center bolt and try again
Dan's thoughts were like mine - I wondered if the washer was still in there. A stock balancer shouldnt be too stuck in there..............
Good luck.
At least you didnt break the puller - that's happened before when the washer causes a bind.
Good luck with the rest of the haul.
