HELP PLEASE!!
  • Thread starter Thread starter jdgt281
  • Start date Start date Oct 9, 2007
J
jdgt281
20
Florence, Alabama
Oct 9, 2007
  • Oct 9, 2007
Hey guys, i have been havin a noise problem from my 89 coupe since i bought it.. Well i pulled rocker arms off and the pushrods out and soon noticed a problem one pushrod was stock length and all the others were longer!! WTF. Also all the long ones were slightly bent and the stock one was fine. The motor is a 306 with World product Roush 200 heads, Lunati Cam, Erson 1.6 roller rockers. Can anyone tell me what length pushrods i need for this so i dont have to buy a checker. I figure someone has had this problem. The heads do have guideplates also. Thanks in advance.
PUNISHER RACING
1,124
FORD CITY, PA.
Oct 10, 2007
  • Oct 10, 2007
If you have bent rods you might of had a little valve on piston action. Bring your #1 cylinder up to tdc and use your 6.250 pushrod as your checker. Place it in the intake valve side first color your valve stem with dark sharpy marker put on you rocker and set your valves as if you would any other time. Rotate motor over by hand. Remove your rocker and check the line on your valve stem it should ride in the center of the stem. If so try exhaust side and if you get the same result buy a stock set of pushrods and have at it.
J
jerryD
1,061
Gladstone, MO
Oct 10, 2007
  • Oct 10, 2007
since you say you have bent pushrods, best bet is it to do a leak down test to make sure you don't have any bent valves. we can't really tell you the right length pushrods to buy, only guesstimate. to find the correct length you will have to buy a rod checker.
G
Engine Pushrod Length Question
  • germain101
  • Sep 22, 2025
Fox 5.0 Mustang Tech Sep 25, 2025
Engine Finishing up 331 build
  • RedFury5.0
  • Mar 21, 2025
Fox 5.0 Mustang Tech Apr 20, 2025
RedFury5.0
Engine Pushrod Length?
  • foxbodyclark
  • Jan 25, 2025
Fox 5.0 Mustang Tech Jan 25, 2025
limp
T
408w pushrods
  • Towegage
  • Sep 19, 2025
  • Fox Engine Swaparoo
Fox Engine Swaparoo Sep 19, 2025
A
Valvetrain help
  • Angelq1028
  • Dec 20, 2024
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Dec 21, 2024
limp
