okay so i decided to jump on the PMS band wagon and will be buying one shortly
In the past two weeks i did the following to the car
fox body t/b conversion ( fox upper ,75mm t/b ,egr delete)
42lb injectors
pro m mass air recalibrated for 42lb injectors
new 3in charge pipe
hks bypass valve recirculated back to the a AFM power pipe
now my questions are will the car turn back on with out a tune
and when i do first get the pms what should be the first thing i should to get the car tuned and finally running
and does anyone have any pics of the pms mounted montior and processor and is there anything that u guys think i might be missing for the car to run right
42lb injectors
new 3in charge pipe
