Help quieting the 3650
  • Thread starter Thread starter 65fastback2+2
  • Start date Start date Jan 6, 2007
65fastback2+2
1,229
Louisville, KY
Jan 6, 2007
  • Jan 6, 2007
Its like driving around with a clothes dryer of marbles at my side....when you can hear it over the radio and exhaust...you know its gonna be annoying...
any of you guys had any luck quieting em down?
I think mine is partially screwed because over 6k rpm it wont even go into 3rd.
evol04gt
29
wadsworth ohio
Jan 6, 2007
  • Jan 6, 2007
is the shifter mount pattern a 6 bolt rectangle or are the two front bolts more narrow? Check your syncros??
stangman
2,690
10
69
in a 3 bed, 2 bath
Jan 7, 2007
  • Jan 7, 2007
i know i'll prolly be more of a frustration with this cause i can't remember the name of it
but they do make a gasket that's supposed to help cut down on the noise
BennyBlown2v
1,233
Carmel, INdiana
Jan 7, 2007
  • Jan 7, 2007
flush/fill trans with proper ammount of atf, get an MGW shifter, get/make a shifter gasket.
Mustang5L5
Mod Dude
Feb 18, 2001
43,374
18,121
224
Massachusetts
Jan 7, 2007
  • Jan 7, 2007
65fastback2+2 said:
any of you guys had any luck quieting em down?.
Mine's is completely silent already
Give Me TP
936
Republic of Texas
Jan 8, 2007
  • Jan 8, 2007
I drained the factory fill and used 3.0L (about 3.2 quarts) of DEXRON III on Tremec's recommendation of a few years ago when I installed a short-throw shifter. Absolutely no problems with excessive noise, third gear lockout, etc. since then.
The gasket some people have used is from CobraBob. I didn't know about those when I installed my shifter, and used Prematex "Right Stuff" sealant (similar if not identical to the OEM material) instead.
V6 to V8 Swap info
  • 02_2v_Curtis
  • Jan 11, 2026
1996 - 2004 SN95 Mustang -General/Talk- Oct 7, 2026
2v_johnny
J
2004 Mustang 3.8L V6 vibrations above 65 MPH and differential leaks
  • joeybuddy96
  • Mar 16, 2026
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech Aug 29, 2026
joeybuddy96
J
Questions About T5 Manual
  • Blackout67
  • Apr 13, 2025
1996 - 2004 SN95 Mustang -General/Talk- Apr 22, 2025
89ripper
is my car dead
  • kenzo0315
  • Jun 30, 2025
SN95 V6 Mustang Tech Jul 8, 2025
kenzo0315
K
TKX Transmission Shifting Problem
  • KWC156
  • Jun 23, 2025
  • Other Auto Tech
3K
Other Auto Tech Jun 13, 2026
427nostang
