HELP! [sorta urgent]
tthree
So i had my windows rolled down a bit and I went to rais them and the switch didn't work. None of the 4 switches on the drivers side work (ie driver,passenger, and both back). I can't check with the passenger side cuz it's never worked. I already checked the window fuse. ANy ideas???
rain is coming tomorrow and I'd hate to not have this fixed :(
Try pulling the door armrest/window switch cluster off (2 bolts) and checking for loose connections. If the connections are good, i would assume the switch went bad. Im not to sure if this will solve your problem but should only take 10 minutes so worth a try! Good luck man.
i have seen the connections get corroded and cause this problem....i would clean the connections real well and try it... never know it just might work
If I find out it's bad is there a way for me to get the windows up before it rains? I could go and buy another switch when I have a little more freetime.
