wazazzle that's an intuitive thing to come up with- similar to what a suspension or performance shop will do, they can compress them and band them with metal bands, same thing, less possibility of all of them breaking and sending razor sharp metal everywhere. just be sure you have MORe than enough hose clamps if you choose to do it that way
some springs are too tall to unbolt the strut and do it that way, so you leave the strut,spindle, all that connected and just undo the a arm bolts that bolt it to the K member (through the bushings) this puts the right angle on it so you can compress the spring with a floor jack. a bit tricky with new bushings to get the bolt holes lined up but a very easy way overall
