HELP-- tech guys???
1991notchbackLX
1,483
47
48
New York
I ordered a full H/C/I combo from camshaft innovations with a custom ground cam and it included a billet aluminum Comp Cams (9 keyway) timing set
the part number on summit for it is CCA-7138... was i sent the wrong kit?? the cam sprocket wont go on all the way for the thrust bearing to make contact with the thrust plate... the bearing hits the thrust plate bolts
the instructions say this:
Ford Windsor Instructions
To use the thrust bearing in this kit, you will need to counter sink the holes in the thrust plate and use counter sink bolts (not included), that will tighten flush or below the thrust plate surface. NOTE: failure to perform this modification to the thrust plate will destroy the bearing during installation due to the thrust plate bolt to thrust bearingh contact.
i have to take this thing to a machine shop and have them counter sink the bolt holes? WTF?!! PLEASE help or point me in the direction of the right timing set, thanks so much
Chris
You must counter-sink the plate for the screws as the instruction read.
I have this setup... I counter sunk the plate myself using a standard countersink bit.
Help is on the way... you need to contact Jay first!
wow, it seems like a few other guys on here countersunk the bolt holes and used allen screws to hold on their thrust plates and it ended up letting go and chewing up their motors...
i have to wait and get a hold of Jay i guess and see what he says... in the meantime can anyone tell me what timing set would be a direct bolt on?? i have a brand new OEM camshaft thrust plate that i ordered from a ford dealership for a '91 5.0
