HISSIN50 said:did the shop have ANY ideas, or did they just cut you loose?
all fluids are up to snuff (i did not re-read this whole thread, so that has likely been covered).
what kind of lift was it? was the car supported by the tires, or did the legs catch the sub-frame? if it only caught the subframe, i still wonder - that would change all the dynamics under the car.
good luck.
Only ideas he had was clutch or tranny.
Haven't checked any tranny fluids yet.
Was on "H" lift...two paths for wheels, hydrolics lift up the entire platform with a gap between the two wheel runners. For jacking up the rear, separate hydrolic lift built into the platform, solid bar under rear end (matching up with wheels) that had about 6" of space from where it ended and wheels were on each side. (I hope that all makes some sense).
