HELP! The 5.0 has an ignition miss!?! What is it??
t_towner
14
Tulsa OK
HELP! :scratch: I bought a '93 Cobra not overly long ago and decided to change the plugs along w/ the cap and rotor before heading off to a car show. After replacement the car seems to run fine for most of the day. Later that afternoon it begin to have problem in the upper RPM range. At 4,000 to 4,500 rpm then starts to cut out and sputter in all gears. The car has 70k miles and had the original plug wires. I took off the original rubber boot and changed out the plug wires thinking that would do the trick but no luck.
I removed some old split fire plugs and installed Bosh Platinum’s, along with a replacement cap and rotor from AutoZone. As mentioned it starts and seems to run fine (maybe with slightly less power.) Over 4,000 rpm it really begins to cut out. Haven’t checked the plugs but plan to shortly. Figured if it was a dead cylinder (er plug) then it would cut out across the rpm band? What’s going on!?! Anyone else had this problem?
Thanks!
I would pull the codes. While doing so, run a cylinder balance test.
Are you sure you are not losing fuel (a lean miss) at higher revs, or that your coil is not on the outs?
If it did not do this before the cap/rotor change, I would put the old stuff back in and see if it fixes it. If so, you got a defective cap.........
And plat plugs can cause a high-RPM miss all themselves. The plat is not as conductive as copper, so copper plugs might be a wiser choice.
Good luck.
Follow Hissin50's advice first and if that doesn't fix it, replace the TFI. The failure mode for the TFI is a high RPM miss on a warm engine.
