Help whats wrong with my car. timing jumpin around and exhaust leak sound
it started after i did a burn out n reved it up n launched it.. i check all the exhaust, spark plugs, and put new gas in it. timing goes from 15-25. idles like sh1t- sounds like its gona cut out, when u drive it it boggs out really bad and sounds like a sh1tty exhaust leak, has no power, taping noise coming from like under intake manifold, back fires when i drive. anything else it could be other then vaccuum leaks and exhaust leak?
gts95mustang said:
ya i pulled the sprout out and still moved around ya it sounds diff when i crank it up.
Again, if the t chain & gears have lots of wear on them, the chain has stretched so much that it is possible to have the cam or crank slip on the chain and they are not in time with each other any more.
Some symptoms of this would be:
Cranks fast then slow when trying to start the motor
Idles rough
At idle, give it gas and it backfires through the intake
Needless to say, it won't run right if you try to drive it
Later
Grady
