Help with injector, maf and t/b sizing
DarkProphet
391
Quakertown, PA
I am going to be upgrading to the 9# pulley.
What size injectors would you suggest without having to use an fmu? I was thinking of going with 36# injectors (found them for 150 in great shape used). Also, my friend gave me a 73 mm c&l maf. Will this work (i know i have to switch out the calibration tube for the injectors), or do i need a bigger one?. Finally, i was thinking about getting a TB to go along with the cobra upper and lower. Should i go with a 70mm or a 75? After all of this is done it will be going to a shop to get tuned and a chip burned.
Thanks alot!
36's should be ok for stock heads. If you ever upgrade, though, you'll need bigger.
That said, if you go bigger than 36's you'll also likely have startup and drivability issues. 42's are notorious for this.
The Cobra intake will have to be matched to a 75mm TB, maybe even a 70. This change will also bring idling issues, as it will have more airflow at idle and maybe enough to get out of the range that the computer can compensate for.
I think I'd get the 36's for now.
If you have a 73mm MAF, and a 75mm TB, then the MAF becomes a bottleneck.
A free MAF is nothing to sneeze at, so I think I would use it.
Also, do you have a way to control timing, as you'll likely see some detonation, if you don't already. 9lbs is where Powerdyne started adding stuff to their kits.
Dennis
well i have the bypass kit and a 255 lph fuel pump. I have no way of changing the timing now, but it will go up for a custom chip and dyno tune soon after being completed.
Which would you suggest as far as the throttle body? the 70 or 75?
75mm TB. Seems to me, in general, that the more air in = more air out = more horsepower, especially with a poweradder when you're trying to stuff air in as fast as possible.
just my two cents, I don't have a power adder, just seems to make sense to this guy.
- adam
bigger is not always better. 36's and a 70mm t/b will work just fine. with the bd11a and the 9lb pulley, i was not able to see more than 7psi. i had 42's, a 255lph in tank pump, and the stock mass air meter (compensation for injectors was done with a tweecer) at the time and was running pig rich. even still though, an msd btm would be a good choice to help prevent any boost/timing related problems.
With the blower, how did you keep from pegging the stock maf???????????
Later
Grady
is it just me or doesnt this guy need a blow through,or whatever its called,maf?and,correct me if i am wrong,but i thought i read somewhere that the general rule of thumb was to keep the maf 5-10mm bigger than the tb?i think george klass,the guy that runs accufab,said that.as stated by a50sn95 the maf becomes the bottle neck and you do not want that,so if it was me i would get a bigger maf,maybe 80mm pro-m.but thats just my .02.the cobra intake will take a 70mm tb,inlet on all cobra intakes is 70mm.if you use a 75mm tb you will have to match the inlet to the tb.i think the only intake made with a 75mm inlet is the tfs intakes.
since the mass air meter is before the blower and sees no boost, a blow through is not necessary. as far as the meter needing to be 5-10mm bigger than the throttle body, i havent heard that before. hopefully someone that knows for certain chimes in soon since im about to pick up my meter, throttle body, and a few other odds and ends.
thanks for the link! it helped out alot as far as TB sizing. It didnt mention anything about a maf that I saw, but i could have missed it. I am just going ot be going with a 70mm TB. The 73mm maf should be an 80 i know, but it was free.... so i wont complain for now...
