I am swapping my rearend for a 9" that I found. Car is a 66 mustang with drum brakes. I have some questions...
There is a "distrubution block" on my rearend...i dont think its suppose to come off. It has two hard lines that run out of it to my drums. It has a soft line that runs up into the body (i need to replace this because it is rotted) - however, i have no idea what that line is for or where it goes. Then there is another soft line that has a fitting like an AC line on the distribution block end and what looks like a nut-type fitting that screws into a hard line that runs to the front of the car.
I can easily remove the one rotted softline....but the other line i guess is my question. I assume that i remove it where it meets the hardline on the 'nut' end and the whole rearend drops out with the hard lines and distrubution block still in tact. Is this right?
Any help would be appreciated
Shane
Shane
