Hello All:
I have a bit of a puzzle to see if you can help me with.
I just picked up a T-5 off of Craigslist with a Hurst shifter for $100. It has a problem with 2nd gear, otherwise it works fine. I have already verified by checking the diameter of the pilot bearing section of the input shaft that it is a V8 gearbox. The seller said it is from a 92 Mustang GT. I think it is from an 89. As much as anything, I'm trying to verify that it's a world class box.
The tag is gone, so I have to look for other clues. The casting numbers are:
13-52-066-919 (tailshaft)
13-52-065-908 (front case)
13-52-027-908 (bearing retainer)
an 89 is inside the starburst that I think is the casting date on the top cover and on the front case. Two of the boxes have dots in them (Feb 1989?) on each of them.
It has a yellow 7 tooth speedo gear. From what I can find, 1990 and up use an 8T speedo gear.
I am pretty sure it is a world-class box and don't doubt it was removed from a 92, but think it's from an 89.
Any help would be appreciated.
Thanks!
Thanks!
