Help with these Codes
Morales
136
Miami, FL
My cars "Check Engine" light has been coming on and off. It's mostly in the morning when the car's been sitting in the garage over night. It will come on and off for a few min and stop. I plugged in my scanner and pulled these codes.
67 O - Neutral Drive Switch (NDS) circuit failure, circuit open; or AC Input High
67 O - Manual Lever Position (MLP) sensor out of range; or AC input High
10 - ????
31 C - EVP or PFE circut below minimum voltage
I have no idea what's going on or where to begin. Can anyone help me diagnose the problem and help me figure out what part I should change.
Thanks in advance
Code 67 - clutch not depressed (5 speed) or car not in neutral or park (auto) or A/C in On position when codes where dumped. Possible neutral safety switch or wiring problem. This code may prevent you from running the Key On Engine On tests. You can generally ignore this code, since it has no effect on engine performance.
Code 10 - No code 10 in any of the listing I have. Please try again.
CODE: 31 (KOEO) - EVP circuit below minimum voltage. Vref (5 volt reference voltage supplied by the computer) missing or broken wire or bad connection in circuit. Use a DVM to check for 5 volts on the orange/white wire. If it is missing, look for +5 volts at the orange/white wire on the TPS or MAP sensor located on the firewall near the center of the car. Use the black/white wire for the ground for the DVM.
With the sensor removed from the EGR and still connected, press the plunger and watch the voltage change on the brown/lt green wire. Pull the passenger side kick panel and measure the voltage at the computer. You will need to remove the plastic cover over the wires and probe them from the backside. A safety pin may prove very useful for this task. Use pin 27, EVR input (brown/lt green wire) and pin 46, signal ground (black/white wire) to measure the voltage. The orange/white wire is Vref and should always be 5 volts -/+ .25 volt. Be sure to measure Vref at the EGR sensor to rule out any broken wires or bad connections.
sunil6784 said:
JRickhker, Cant Code 67 come on if the defrost is on also? thats what happened to me. I turned the defrost off and I didn't get the code.
The Defrost kicks on the A/C to dry out the air.
