  • 1994 - 1995 Specific Tech
Help with Tweecer and MAF
  • Thread starter Thread starter TrueBlue95GT
  • Start date Start date Nov 5, 2004
TrueBlue95GT
966
Connecticut
Nov 5, 2004
  • Nov 5, 2004
If I get a 80mm Pro-M calibrated for 36lb/hr injectors and I only have 19lb/hr injectors, can I use my tweecer to make it work? I found one really cheap and I'd rather not pay Pro-M to recalibrate it.
M
mackey
1,284
Beverly, Massachusetts
Nov 5, 2004
  • Nov 5, 2004
ttt. I am pretty sure you can. Post on the tweecer forums. How much did you pay for your tweecer and where did you get it? If you don't mind me asking
BlackVert
5,589
9
98
Bethesda, MD
Nov 5, 2004
  • Nov 5, 2004
if you have an accurate flow sheet for it, it should work.
95BlackTan50
116
  • Nov 5, 2004
All you need to do is enter the flow numbers into the MAF function. There is a utility to convert the 9 point numbers into the 30 points that you need for the function. If you didn't get a flow sheet, you can get it from the ProM web site.
TrueBlue95GT
966
Connecticut
Nov 5, 2004
  • Nov 5, 2004
Can the flow sheet from the Pro-M website work or does it have to be a custom flow sheet?
94GTLaserRC
Squint as you approach, lest you be blinded by my
11,178
Ernan Says "here it comes... dushbag"
Nov 5, 2004
  • Nov 5, 2004
Screw all that...
All you gotta do is change your injector slopes to tell it you have 19lb injectors.
That's all I did when I changed from 30's to 36's with the MAM still set for 30.
GL.
RC
Zero Signal
2,633
Tucson, AZ
Nov 6, 2004
  • Nov 6, 2004
Yeah you can change your injector slopes or the MAF transfer. I would just enter the transfer curve they give you then change your injector slopes untill you're running about the right AFR.
BlackVert
5,589
9
98
Bethesda, MD
Nov 6, 2004
  • Nov 6, 2004
there's a guy selling one for $500 here
http://autos.groups.yahoo.com/group/tweecer/message/12323
or ppl sell them here from time to time
http://tweecer.oplnk.net/viewforum.php?f=6
- Chris
Pro-M 75MM Bullet Flow Sheet - Is this calibrated for 36 # injectors?
  • dan50
  • Jan 11, 2026
  • Digital Self-tuning Forum
Digital Self-tuning Forum Jan 11, 2026
dan50
M
a Pro-M EFI system
  • maximilian macdoanald
  • Feb 6, 2026
Digital Self-tuning Forum Jun 5, 2026
X-cam34
Free VE Table Corrections — Drop Your MSQ and a Datalog, I'll Do the Rest
  • X-cam34
  • Apr 12, 2026
  • 2 3
2K
Digital Self-tuning Forum Aug 26, 2026
X-cam34
Engine on3 Conversion to draw through MAF?
  • sav22rem22
  • Oct 11, 2025
Fox 5.0 Mustang Tech Oct 11, 2025
sav22rem22
Drivetrain Wilwood Clutch and Brake Pedal Combo Installation - Help
  • 427stang
  • Jul 8, 2026
Fox 5.0 Mustang Tech Jul 8, 2026
427stang
