Today I decided to install my steeda underdrive pulleys on my 05' mustang gt(automatic). I pretty much followed the instructions that bigcat provided on this website. I came across two problems though.
The least important one is that when I tried to remove the bolt from the alternator support bracket(lower driverside one) the nut would come off but the bolt did not. Has anyone with steeda udp's ever had this problem?
The most important problem occurred when I was installing the steeda harmonic balancer pulley. I tried using the bolt they provide to get it started(they warn to not fully tighten this bolt, because it can cause damage), but when I removed that one and tried to put the stock bolt(which the steeda directions say to re-use) back in, the pulley was not far enough onto the engine. So I used the chrysler pulley remover/installer that I rented, and this is where the problem occurred. I'll explain what I did step by step. First I found the adapter with the correct threading. Then I attached the black ring(the thing that's supposed to keep the adapter and the pulley installer bolt together) to the adapter. Then I put the nut and spacer onto the pulley installer bolt. Then I screwed in the adapter into the pulley installer bolt, and tightened the black ring. Then I started to put the harmonic balancer pulley onto the engine. After getting to a point to where I thought the stock bolt would actually grab hold of the threads in the crank, I began to loosen the adapter/pulley installer bolt. I didn't notice it at first but the adapter had separated from the pulley installer bolt, and remained attached to the pulley/crank. I cannot figure out how to get the adapter out. Since the black ring is still threaded on the adapter, much of the adapter is not exposed(eyeballing I would say 1'' to 11/2'' of exposed threading). I've tried putting duct tape on the exposed threads and using a variety of pliers to try and loosen it, but no luck(because of how deep the middle of the pulley is, I can only grab the adapter straight on, not from the side). Has this happened to anyone, or does any one have any ideas about how to get it out?
The only thing I can think of now is to find a proper sized nut, and use some threadlock to hopefully keep the nut and adapter attached to where I can use a socket.
I know this is pretty long and not well written, but I'm frustrated. Not to mention a huge blow to my ego for making a mistake like that. Believe me, any help will be greatly appreciated.
. oh yea, when you re-used the factory harmonic pulley bolt, did you re-use that thick washer as well? I noticed that without it would work, but I wasn't sure if I needed it or not. thanks for your help
