Good afternoon. I've read through all of the forums that I can find in particular....
Long story short I recently inherited a 1993 Mustang GT convertible 5.0 with a Ado transmission in it.
I've slowly been working on things here and there the starter was out in an initially the car hadn't ran in probably 18 months and maybe 2 years fired her up and re placed the starter relay , replaced spark plugs and gone down the road replacing some basic things and it ran just fine. Driving it on the highway about 200 miles into our trip started having slight surges and then got to the point that RPMs are running high and I was losing power. I discovered that one of the vacuum lines had broke as it was very brittle but I haven't driven it since I replaced that vacuum line that went from the distributor to the splicer connector that then ran to the EGR valve.
Took it to a Ford dealership because it literally broke down right by a dealership and he told me that it was the transmission even when I told him to check the vacuum lines. And he wouldn't tell me if it threw any codes or not. I have a code reader for this car and I've put it on there and I got a flashing box one time and then nothing I tried it several times and still nothing. Smoke test only showed slight smoke coming from the EGR valve. Again I have not driven it since I have replaced all of these items.
To date I have changed the spark plugs and put eight motorcraft ones in there, the EGR valve, the EGR valve sensor, Throttle position sensor, flushed and change the power steering fluid, oil and transmission fluid (which was dark but no large metal shavings), replaced the vacuum lines with a set from LMR. I have not ran it on the road since replacing all of those things. It does have a slight rough idle and I have not adjusted the idle yet. Is there anything else I am missing? I'm very Hands-On with cars I love working under the engines I have no problem working on things but to me it doesn't sound like a transmission issue it sounds like I had a vacuum leak and watching a lot of videos and reading a lot of forums they all kind of say the same thing.
Also I am replacing the bushings and the front and rear quarter window (it's a convertible) and for the life of me I cannot get the rod to line back up to go down into the hole. I've been at this thing for hours the only thing I can think of is maybe I need to remove the window motor so I can move the track more freely? I did remove and replace the bushings and all four motor Windows because they were all shot to crap and they are all up and running again.
I know this is a multi question post but I'm slowly restoring her it's in really good shape for the year that it is they took really good care of it but I've been slowly replacing things here and there buying everything from LMR directly.
Thanks
Thanks
