Help
  • Thread starter Thread starter wazazzle
  • Start date Start date Jul 5, 2005
W
wazazzle
618
In the dumpster behind McDonalds. WA
Jul 5, 2005
  • Jul 5, 2005
coming home from work was at a stop light when car just died. no signs of trouble at all, then just dead. car is basically stock 165k never rebuilt. (i'm avoiding rebuild cause i'm thinking of 351w swap next yr.) tried starting and wouldn't even crank over. had towed back home $$$. took a look, everything looks good-fluids, connections, starter, sylinoid, plugs, wires, no leaks, nothing seems wrong. had my brother try to crank her, i can smell gas coming from tail pipes. just not cranking over. thought fuel lines and pump are new. sprayed gas into intake manifold to see if sparks up and turns over. NOTHING! tried twice, still nothing. plugs and wires are new too, so i'm thinking its the ignition box??!! what do you guys think, anything else it maybe. please help...
9250stang
927
Kentucky
Jul 5, 2005
  • Jul 5, 2005
Timing chain might have kicked the bucket. 165k miles is a lot of wear and tear on that thing.
Had a car crap out on me in mid-drive like that before, that's what it ended up being.
G
Gargamel
Chicago
Jul 6, 2005
  • Jul 6, 2005
Did you look at your TFI ignition module??? Had my stang do exact same thing. Replaced and runs like a dream.
W
wazazzle
618
Jul 6, 2005
  • Jul 6, 2005
if it's the TFI/ignition module it should start in the morning then after sitting all night. i know fords have that problem of the TFI overheating and becoming unfunctional. it's because they're mounted on the distributors towards the center of the engine, where it's hot. most people just wait and start the car again later. mine didn't do that when i got it home. but i will try it again in the morning
HISSIN50
34
129
Jul 6, 2005
  • Jul 6, 2005
So you have Fuel pressure? If the PIP were to go south, you would have neither spark nor injector pulsing (though you would have fuel pressure). Just FYI.
A parts store should be able to bench test the TFI (have them test it repeatedly to heat it up).
Do you have any codes? IDM codes should be jumped all over.
Good luck.
W
wazazzle
618
Jul 6, 2005
  • Jul 6, 2005
jrichker
StangNet's favorite TOOL
Mar 10, 2000
27,512
2,813
234
Dublin GA
Jul 6, 2005
  • Jul 6, 2005
Cranks OK, but No Start Checklist for Fuel Injected Mustangs
1.) Remove push on connector from starter solenoid and turn ignition switch on. Place car in neutral or Park. Remove coil wire from distributor & and hold 3/8” away from engine block. Jumper the screw to the big bolt on the starter solenoid that has the battery wire connected to it. You should get a nice fat blue spark.
A.) MSD or Crane ignition box if so equipped
B.) Coil
C.) TFI module
D.) PIP sensor in distributor
E.) ECC relay next to computer - look for 12 volts at the fuel injector red wires
F.) Fuse links in wiring harness - look for 12 volts at the fuel injector red wires. All the fuse links live in a bundle up near the starter solenoid.
G.) Ignition switch - look for 12 volts at the ignition coil red/lt green wire.
H.) Computer
See the following links for wiring diagrams...
http://www.autozone.com/servlet/UiB..._us/0900823d/80/16/71/3c/0900823d8016713c.jsp for 79-88 model cars
http://www.autozone.com/servlet/UiB..._us/0900823d/80/19/59/5a/0900823d8019595a.jsp for 89-93 model cars
http://www.autozone.com/servlet/UiB..._us/0900823d/80/1d/db/3c/0900823d801ddb3c.jsp for 94-98 model cars
2.) Spark at coil wire, pull #1 plug wire off at the spark plug and check to see spark. No spark, possible failed items in order of their probability:
B.) Distributor cap
C.) Rotor
D.) Spark Plug wires
Two reasons:
Clue – listen for the fuel pump to prime when you first turn the ignition switch on. It should run for 5-20 seconds and shut off. To trick the fuel pump into running, find the ECC test connector and jump the connector in the lower RH corner to ground. See http://www.mustangworks.com/article...c-iv_codes.html for a description of the test connector. If the relay & inertia switch are OK, you will have power to the pump. Check fuel pressure – remove the cap from the schrader valve behind the alternator and depress the core. Fuel should squirt out, catch it in a rag. Beware of fire hazard when you do this. In pinch you can use a tire pressure gauge to measure the fuel pressure. It may not be completely accurate, but you will have some clue as to how much pressure you have.
No fuel pressure, possible failed items in order of their probability:
C.) Clogged fuel filter
D.) Failed fuel pump
E.) Blown fuse link in wiring harness. Look for 12 volts at the Orange/Lt Blue wire on the fuel pump relay. The fuse links live in the wiring harness near the starter solenoid.
F.) Fuel pressure regulator failed. Remove vacuum line from regulator and inspect for fuel escaping while pump is running.
Fuel pressure OK, the injectors are not firing.
A.) A Noid light available from Autozone, is one way to test the injector wiring.
B.) I like to use an old injector with compressed air applied to the injector where the fuel rail would normally connect. I hook the whole thing up, apply compressed air to the injector and stick it in a paper cup of soapy water. When the engine cranks with the ignition switch on, if the injector fires, it makes bubbles. Cheap if you have the stuff laying around, and works good too.
a.) Pull an injector wire connector off and look for 12 volts on the red wire when the ignition switch is on.
b.) No power, then look for problems with the 10 pin connecter (salt & pepper shakers at the rear of the upper manifold).
c.) No power and the 10 pin connections are good: look for broken wiring between the orange/black wire on the ECC relay and the red wire for the 10 pin connectors.
4.) Spark & fuel pressure OK.
A.) Failed IAB (no airflow to start engine). Press the throttle ¼ way down and try to start the car.
C.) Engine ignition or cam timing off: only likely if the engine has been worked on recently).
HO & 351W 1-3-7-2-6-5-4-8
Non HO 1-5-4-2-6-3-7-8
E.) No start when hot - Press the throttle to the floor & try starting it if you get this far. If it starts, replace the ECT.
W
wazazzle
618
Jul 6, 2005
  • Jul 6, 2005
bump
HISSIN50
34
129
Jul 6, 2005
  • Jul 6, 2005
wazazzle said:
bump
Where are the psychic members when you need them?
You are going to have to do some troubleshooting on your own. And then people here can help by analyzing the data/observations you provide. That list by JR is an awesome place to start.
Good luck.
C
Electrical Fuel Gauge...Help! What did I do or Didn't Do?
  • ChickenDeluxe
  • Sep 3, 2026
Fox 5.0 Mustang Tech Sep 3, 2026
ChickenDeluxe
C
C
Electrical HELP! 1989 5.0 Stick, Voltage Bleed onto Ignition Trigger wire
  • ChickenDeluxe
  • May 14, 2026
Fox 5.0 Mustang Tech May 24, 2026
ChickenDeluxe
C
Engine Coolant boiling in hose?
  • Teen'93stang5.0
  • Jun 3, 2026
Fox 5.0 Mustang Tech Jun 8, 2026
Mustang5L5
Engine Another no start after washing engine bay
  • bruno
  • Apr 26, 2026
Fox 5.0 Mustang Tech May 7, 2026
AeroCoupe
A
1987 5.0 speed density Foxbody crank no start
  • Alan2204
  • May 23, 2026
Fox 5.0 Mustang Tech May 30, 2026
Mcmahst
