  • 1994 - 1995 Specific Tech
HELP
  • Thread starter Thread starter 94_5.0
  • Start date Start date Apr 21, 2006
9
94_5.0
337
Jacksonville, NC
Apr 21, 2006
  • Apr 21, 2006
Well I was on my way home today and the car started to make this wierd creaking noise under acceleration, however it was not to bad so I went on driving. Alittle bit further down the raod i noticed that my Autometer Temp guage had pegged its self past the 250 degree mark and that is when I noticed that the creaking noise had gotten worse(kinda like loose metel shaking all over the place). As i tried to make it home it got worse and worse...my check engine light came on and my overflow tank blew its top and shot water all over the place. When I made it home it started to shoot white smoke out the rear end. When I opened the hood nothing (other that the water all over the place) seemed out of place. there were small pools of lquid bubbling near the water pump, the oil dip stick tube seems really loose, and my spacer on the intake mamfold was wet, that is the only yhting that was odd in the engine. the headers were on tight and everthing else was in its proper place. Please help me with this delima I am at a complete loss.
P.S. the resivor(sp) was full of water and white floating stuff.
mootang
907
texas
Apr 22, 2006
  • Apr 22, 2006
sounds like maybe your water pump took a crap and then you overheated your car and possibly blew a head gasket.
9
94_5.0
337
Jacksonville, NC
Apr 22, 2006
  • Apr 22, 2006
i hope i di dnot blow the head gasget
there was no oil or anything in the engine compartment
mootang
907
texas
Apr 22, 2006
  • Apr 22, 2006
drain your oil and see if it is milky looking.
Swarzkopf
973
Pittsburgh
Apr 22, 2006
  • Apr 22, 2006
No offense dude...
But do you think that maybe you should have stopped the car at some point after you started hearing weird engine noises, had your temp gauge pegged, and boiled over your overflow tank!?
You blew a headgasket because you way overheated your engine. I don't know why you expect to see "oil in the engine compartment" due to a blown headgasket...but the tell-tale signs are all there. That white smoke from the rear end? That's coolant coming out of your tailpipes.
As to WHY you initially overheated and blew a headgasket, like mootang originally said, your waterpump probably took a ****, explaining the weird noise you were hearing.
If you would have stopped the car, you probably would have had to have replaced the waterpump and thats it.
Now not only will you have to replace the headgasket, you'll have to make sure you didn't damage your motor as well (water in the oil isn't good for bearings).
9
94_5.0
337
Jacksonville, NC
Apr 22, 2006
  • Apr 22, 2006
i could not stop i was on a freway and in hawaii if you leave your car there u get towed by the cops... and the oil is fine nice and black (lol). i think my h2o pump is ok but my therostat is the problem going to pull it now to see.
mootang
907
texas
Apr 23, 2006
  • Apr 23, 2006
hopefully that is all thats wrong with it. good luck.
9
94_5.0
337
Jacksonville, NC
Apr 23, 2006
  • Apr 23, 2006
i hope so too thanks
mo_dingo
20+ Year Stangneter
Aug 26, 2003
3,031
Tucson, AZ
Apr 23, 2006
  • Apr 23, 2006
white smoke out the tailpipes = coolant in the pistons....you may not be leaking into the oil passages yet, so it's just getting into the rear pistons. The coolant passages are so close to the rear pistons, they might only be going there, for now.
Not to censure you, but I hope this is a lesson to you. Sorry that is happened, but maybe now you know.
Scott
9
94_5.0
337
Jacksonville, NC
Apr 23, 2006
#10
  • Apr 23, 2006
  • #10
Well it is offical not only did i blow the heads but some how I broke the fuel line that connects the 2 fuel rails together it was squirting out when the fuel pump primed. now it is time to rip apart the engine i guess. yeah i learned that when it over heats to just stop driving right then and there not to "try and make it home".
2000 GT-Front Brakes Not Releasing
  • stormsedge
  • Aug 7, 2026
1996 - 2004 SN95 Mustang -General/Talk- Aug 7, 2026
Bronco2fan
Engine Strange Noise
  • burntokita
  • May 8, 2026
Fox 5.0 Mustang Tech May 11, 2026
keel
Removing speedo cable from the VSS
  • 91AOD5.0LX
  • Mar 25, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Apr 25, 2026
91AOD5.0LX
Buying with a bad motor?
  • djj62478
  • Mar 8, 2026
1996 - 2004 SN95 Mustang -General/Talk- Mar 11, 2026
TTSaleen
M
1991 GT cigarette lighter/port not working (horn is working)
  • MartinM
  • Aug 29, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 30, 2025
MartinM
M
