hesitation and dying
taker73044
15
ok heres the problem when i first start my car i have to hold the gas for a min or so. then it will idle after i let off but it idles rough. After it warms up it smooths out.seems to still be a slit miss thoo. now when it is idling if i rev it you can barly hear it hesitate. have to listen real close to hear it. now when i get it on the street she drives fine but when i accell hard from a stop she spudders and dies
also if i accell hard while moving she spuders for a sec or to then picks up. if i power brake she will burn the meat off rims lol but when i let off she dies. i have re droped the dis. tons of times to make sure i had it right and i do droped it at 0 tdc pointing at #1 also tried what chiltons man. said that was to set it tdc then move it to my timing mark 10 btdc then line up the stator in the dis. and piont at #1 so i know its not the timing.
Note: no backfiring has been noticed
have you pulled the plugs to see if your running to rich?
it has only been running for about 2 months so the milage is less than 300. its has been doing this from day one even got rid of the brock and put a holley on it in hopes to fix it.
got the elderbrock proflo on it for air filter . not a stupid question air filter makes a big diferance lol.
is the car with you right now? if your able go pull the air filter off real quick and start it up...see if it is just getting starved for air. sounds to me liek to much gas is getting dumped into the cylinders.
