hesitation and dying
  • Thread starter Thread starter taker73044
  • Start date Start date Dec 22, 2006
First Prev 2 of 2
T
taker73044
15
#21
  • Dec 23, 2006
  • #21
is that your car in the pic
T
taker73044
15
#22
  • Dec 23, 2006
  • #22
i got a clear view fuel filter i noticed that it was full then about 20 min later it was almost emptyit was about 1/4 full i reset the timing to 10 btdc and it dont smell rich anymore but now im hearing a odd exuast sound coming out of the driverside
exuast my fireing order is 13726548 man this sucks lol
pistonhead351
flim hunter
May 1, 2005
75
#23
  • Dec 25, 2006
  • #23
carb man.
jrichker
StangNet's favorite TOOL
Mar 10, 2000
27,512
2,813
234
Dublin GA
Dec 25, 2006
#24
  • Dec 25, 2006
  • #24
pistonhead351 said:
carb man.
That's what he has. That's why he has the off idle acceleration problems common to carb setups that need some really skilled tuning.
I am not a a hair on fire carb guy, but I would look for vacuum leaks and idle bleed screw settings - they cause poor idle quality. For poor acceleration, check for accelerator pump problem or settings. Make sure that pump does squirt, and it does not squirt too little or too late.
A Google sarch for carb tuning will lead you to tons of info on how to tune carbs. Granted that most of it is for SB Chevvy's, but a carb is a a carb and works the same on a Chevvy or Ford.
pistonhead351
flim hunter
May 1, 2005
75
#25
  • Dec 25, 2006
  • #25
yep i would check for leaks mainly the carb gasket. and if it has a spacer make sure to get some good gaskets. take a propane torch with no flame just with the gas coming out, and put it around the gaskets, if the idle jumps thats the problem. you can use carb cleaner also.
jrichker
Mar 10, 2000
27,512
2,813
234
Dublin GA
Dec 25, 2006
#26
  • Dec 25, 2006
  • #26
Richard Pryor, the black comedian who torched himself while freebasing with cocaine said "Fire is a wonderful depilatory". I have always considered that sage advice coming from someone with firsthand experience. Therefore I avoid using highly flammable substances when looking for vacuum leaks. A squirt can of motor oil is a safer, but messier choice.
T
taker73044
15
#27
  • Dec 25, 2006
  • #27
Did check for vac leaks found none. Replaced the base gasket anyways.ordered a 80 gph fuel pump. Going to try to get so bigger jets and plug the power valve see if that helps. it ran tish way when i had the brock on it to. Just changed to holley a few weeks ago. hopeing to solve it .
First Prev 2 of 2
F
Fox 1990 Mustang GT 5.0 A9L – Engine suddenly shuts off but immediately restarts when key turned
  • FishermansFriend
  • Aug 9, 2026
General karthief
T
Help with a 95 5L crank no start
  • TheBubbaJoe
  • Nov 4, 2025
  • 1994 - 1995 Specific Tech
1994 - 1995 Specific Tech Nov 5, 2025
AeroCoupe
Engine Multiple o2 sensor codes, car runs terrible
  • 02newedge
  • Jun 12, 2025
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Jul 19, 2025
squeak93
'03 GT Fuel Pump/Pressure/Delivery Issue
  • Brodach
  • Oct 21, 2025
SN95 4.6L Mustang Tech Oct 31, 2025
gkomo
Z
Progress Thread zeth194 - New Guy on the Block
  • zeth194
  • Mar 19, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Apr 26, 2026
LILCBRA
