Hey carb guys!
flyby84
48
Arkansas
Alright...the combo I have in my sig works pretty good but I have noticed the exhaust from my car will choke you out! I have a stock Holley street avenger and was wondering if this is enough carb or should I get something else? Everyone I have talked to say I should pitch it in the trash...:shrug:
what CFM do you have...570 670 770 870?
Might try running your mixture screws all the way in and then a turn and a half out as a starting point
If this is a 670 Street Avenger then it's not a bad carb for your combo...should run pretty stout. I'd say you just need to tune it a bit. Carb exhaust always smells a little more gamey than an EFI exhaust, especially if you don't have the emissions equipment and cats installed.
Flyby84,
With that cam i would imagine you are making peak power around 5500-6500 RPM, and with your 306 you will be pulling 576cfm@6500rpm, 620cfm@7000rpm and 664cfm@7500rpm - when do you plan on shifting? Your peak cfm should be how you choose a carb becaue of the velocity to vacuum profile as air is drawn thru the venturi. Just remember in this case, bigger is not always better. Good luck!
Walz
^^ Keep in mind that just because a carb is labeled as a 650cfm, doesn't mean it actually flows that. What looks good on paper in a math formula doesn't always work out in the real world. I'd personally say a 650 is about perfect for his setup. With a 600 he may have slightly better throttle response (and i mean slightly) and slightly better bottom end (again, slightly) but he'll more than make up for it in the top end.
My stang pulls pretty hard with this combo! I shift at around 6k and I believe this is a 570cfm!
I am looking foward to running at the local 1/8th in a few weeks to see what it will turn.
What jets are you running and what altitude are you at? Generally you should go down a jet size per 1700ft or so IIRC. The CFM on a carbs rating is aprox how much air it will flow, not how much fuel.
The plugs look just a little bit on the rich side...not much just a little! I just haven`t bought headers yet,they are coming this summer. Looking into getting some longtubes. How much of a performance gain will I pick up with a decent set of LT`s?
