Hi-6 plug gap
Regardless of coil or module, you want to run as much gap as the ignition system will reliably support. So experiment with it - start with stock and work your way up. If you have enough energy to jump a bigger gap, that makes for a big, fat spark exposure to the mixture, and as Martha would say, that's a good thing.
your right ,but thats not regardless of the coil.remember the coil puts out the spark,48,000 volt coil dictates a bigger gap as opposed to the stock coil of 37 or 38.and if your running an msd unit then you can increase the gap even a bit more.
You're misunderstanding my post Sting - didn't intend to imply that the coil wouldn't impact how big a gap you could run -- it will impact it. But, REGARDLESS of what your system is, run as a big a gap as your system will reliably supply. If you have more coil, that gap will be larger. The stock system/coil will support the stock gap of .054 unless you're running more compression or boost. The point is - play with it and see. You won't really hurt anything. You'll get some mis-fire when you get the gap too big -- then back it down from there.
Thanks guys! Don't know what the coil output is. It is a Crane PS-91, and all I can tell you is you don't need a dark room to find an arcing wire. Major lightning bolts! :D You guys ever tried cutting back the ground strap?
I have always read that the stock coil is good for 50,000 volts and the stock gap being between .44-.46.? :shrug:
I do have my ground straps cut back half way over the electrode. Seems to work ok.
I am running the MSD Digital 6 Plus with there new HVC II coil on mine. Plugs gaped at .070, and work fine.
I cut the plug grd to the center of the electrode.
Mild H/C/I combo; stock ignition on mine. I cut back the ground to about half way over the center electrode and run .054". Mileage/drivability/performance have remained unchanged for the last 2 1/2 years and 14K miles - no other changes other than oil/filter.
