Hi, quick question here
interceptor7
59
Anyone know of a source for the slotted socket used on the top of front struts on a 93 GT? I'm trying to install camber/caster plates and I can't get the strut nut off!
If no one knows where I can get the tool, how about another way to get that nut off? I've already snapped the tip of a pry bar off!
BTW, the only online place that I found is Toolsource, but they won't be able to ship until September!
Any suggestions?
On the last ones I did, I hit the fastener with a little PB. Then I used a small prybar like this . I used one of the middle prybar sizes and put the prybar across the slots from the side (not from the top, like you'd have to with a screwdriver).
If that doesnt work, Air tools or a shop can likely help. A shop can blap it loose for you. Then tighten it up enough to safely get home. It should come off easier now.
Good luck.
