High Crankcase Pressure...Bad Noises...Thoughts?
  • Thread starter Thread starter 5.0L Miata
  • Start date Start date May 8, 2009
5.0L Miata
121
Ontario, Canada
May 8, 2009
  • May 8, 2009
Hey All,
I took the car for a quick run last night after getting many of my problems resolved. I installed a professional products 70mm TB that didn't have a spot for the hose from the valve cover to attach to it. Not really thinking about it much I just put a cap on it where the hose used to attach at the oil fill neck (this is a 91 5.0L) a while back and I forgot to resolve this problem.
Anyway, I took it for a quick drive and it was running well and then the engine started making horrible noises. Sounded like no oil situation or something... really bad clanking. I quickly turned the engine off and coasted to the side of the road. When I got out and under the hood I could hear a big "Ping" that sounded like the oil pan contracting back in! I then pulled the dip stick and got a rush of pressure release.
After a couple of seconds of thinking about it I realized I hadn't fixed the valve cover to TB situation, so I pulled the cap off the valve cover nipple and fired it back up...no more noise. I then gingerly drove it home but it seemed fine.
Any thoughts on what the horrible noise I heard was from the high crankcase pressure? Did I starve the engine of oil? I think I'll do a compression test tonight to see if I've screwed up real bad. It would figure just when I get this thing going that I'd screw it up again!
Mustangr
217
boise Id
May 9, 2009
  • May 9, 2009
Wow that was a horrible story. I thought I had crank case vent problems.....Sorry.
A
Resolved 302 oil leak when running
  • AlexM556
  • Sep 8, 2026
Classic Mustang Specific Tech Nov 1, 2026
manicmechanic007
O
Sooty/Oily Front Engine & Pulleys
  • ozenator
  • Jun 15, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 22, 2026
Blackhawkxx
H
Ongoing Battle With Hydraulic Lifters
  • hailer06
  • Jun 8, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 9, 2026
M
01 mustang 3.8 fuel pressure issue
  • Mhaley2006
  • May 29, 2026
1996 - 2004 SN95 Mustang -General/Talk- Aug 9, 2026
JohnKay
J
Engine Gas in my oil
  • limp
  • Jun 15, 2025
2K
Fox 5.0 Mustang Tech May 16, 2026
Mindseye007
