I am having problems diagnosing and fixing this. I have replaced the driveshaft with a FRPP aluminum one and I have replaced the harmonic balancer twice with the FRPP model. The first one went out of balance in the span if a month.
Here is the deal, I am getting a vibration coming through the shifter at around 4 grand in all gears except 5th( it never sees that rpm range) and the vibration, in 5th gear, is prevalent at around 80 mph and higher. I am beginning to think that the vibration is coming from the companion flange on the rear end, or else the pinion bearing is shot.
I am lost any suggestion?
Drew
Drew
