High rpms at shift
  • Thread starter Thread starter noneck134
  • Start date Start date Mar 14, 2008
N
noneck134
24
  • Mar 14, 2008
I know I know, pull codes lol. I will pull them this weekend. Car idles fine and runs good but when i go to shift gears and push in the clutch it stays at the high rpms for a couple of seconds and then goes down. Just wondering if anyone knows a quick check.
88 5.0 stock S/D not mass air.
M
Mike85000
65
  • Mar 14, 2008
Mine does that sometimes a little when cold.
When accelerating easy and shifting the rpms will hang a little in between gears but never more than 1600rpm
Kind of sounds like it could be TPS related. I know mine does't throw any tps codes so i figured it was normal.
Williams57
  • Mar 14, 2008
this may or may not be the problem, but once after using the cruise control on my car, it did the same thing, it would crank the rpm's up cause it saw it was slowing down. It still did this even after shutting it off, but after i pulled the fuse out it quit, i know this sounds weird, but it may be worth a try
N
noneck134
24
  • Mar 14, 2008
Thanks. Thats a couple of things I can check.
T
Drivetrain TREMEC TKX 1–2 Grinding Issue at ~4,000 Miles + Poor Warranty/Customer Service Experience
  • Ttopfoxguy
  • Oct 10, 2026
Fox 5.0 Mustang Tech Oct 15, 2026
JMG9350
J
Engine Random hanging idle
  • 706 Saleen
  • Feb 11, 2026
Fox 5.0 Mustang Tech Feb 19, 2026
86HO5.0
idles perfect then jolts and cuts out when put into Reverse or Drive.
  • shanesstangs
  • Mar 12, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Apr 27, 2026
General karthief
W
Speedometer and shifting issues
  • wyatt-tetro891
  • Aug 17, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 18, 2026
wyatt-tetro891
W
Drivetrain Sticky clutch pedal
  • keel
  • Jul 31, 2025
Fox 5.0 Mustang Tech Oct 17, 2025
Mindseye007
