High Volume Oil pump
the FRPP pump is just the same pump Ford has put in the cobra for decades. Its a good pump for pretty much all of us. Its what I am running on my car. I look at all the cobra pumps out there running on the streets compared to the billet gears running out there and figure the ratio of failures. FAR less FRPP pumps have failed compared to after market gears. That pump can easily handle 7000rpm with out a problem. very very few of us see that rpm.
Properly Spec'd Billet Oil pump gears are better than the stock oil pump gears. There is 0 failures of properly spec'd Billet Oil pump gears which is not the case with the stock or FRPP unit. I run the HV oil pump with properly spec'd Billet Oil pump gears. Depending on the application, the stock oil pump with proper Billet Oil pump gears is more than adequate.
