hindsight is 20/20 and i need the name of a tool
  • Thread starter Thread starter Cobra_Dusten
  • Start date Start date Feb 17, 2009
Cobra_Dusten
246
Marysville, Wa
Feb 17, 2009
  • Feb 17, 2009
Ok, so i just dropped a new motor in my car, stock rebuild on the bottom end with a .030 overbore, gt-40 heads and explorer intake with E-cam. I didnt research the fact my stock springs were no match for this cam. So, here i am with an assembled engine, in car, needing to swap out my valve springs. I had the heads rebuilt before they went off the car, and i tore them down myself so i am familiar with removing the springs. my problem is, i need the name of the tool used to fill the cylinder with compressed air to keep my valves from dropping into the piston.
Thanks guys.
strtrcr50
Previously from Dirty Jerzey exit 7a
Feb 17, 2009
  • Feb 17, 2009
If I recall correctly, you can use a leakdown tester to do that.
D
DrMaxit
139
Augsta GA
Feb 17, 2009
  • Feb 17, 2009
Name of a tool? Obama
Ok all jokes aside, you can use the tube off of a compression tester and hook it up to an air hose to get the job done.
Cobra_Dusten
246
Marysville, Wa
Feb 17, 2009
  • Feb 17, 2009
here is a question for ya, just how much pressure is the air applying to the valve(not psi) but how hard is it to push the valve down?
Cobra_Dusten
246
Marysville, Wa
Feb 18, 2009
  • Feb 18, 2009
well, turns out my dad has one. so i ordered the TFS valve spring kit, and since i was spending more money i ordered the FMS ac delete kit to move my ps pump up. now i just have to go buy a new serp belt.
jrichker
StangNet's favorite TOOL
Mar 10, 2000
27,512
2,813
234
Dublin GA
Feb 18, 2009
  • Feb 18, 2009
Indian rope trick:
An alternative to the compressed air trick is to use a length of 3/8" hemp rope. You stick your finger in the spark plug holes and crank the cylinder up until you feel air blow past you finger. Feed the rope down the spark plug hole until you can't get any more of it in the cylinder. Then use a 15/16" socket to crank the harmonic balancer bolt until the cylinder locks solid. The rope will have filled the combustion chamber and is solid against the valves at that point.
T
Oil burning on my recently buil 302
  • The blk67
  • May 15, 2026
Fox 5.0 Mustang Tech May 15, 2026
Engine Donor '00 Mountaineer meet '91 Fox
  • 91firecracker
  • May 11, 2026
  • 2 3
Fox 5.0 Mustang Tech May 28, 2026
91firecracker
9
Engine Suggestions on an engine rebuild. Stock cam/GT40Ps or aftermarket on both for a fun weekend driver?
  • MadSquirrelTech
  • Apr 28, 2026
Fox 5.0 Mustang Tech May 7, 2026
MadSquirrelTech
H
Forced Induction On3 Turbo Kit- Parts list NEEDED - 302 Stock Motor
  • Hirothecool1
  • Feb 27, 2026
Fox 5.0 Mustang Tech Mar 7, 2026
slow84lx
T
Resolved No run or idle
  • Thebluefox1
  • Oct 10, 2025
Fox 5.0 Mustang Tech Nov 25, 2025
DadLife0724
