- Oct 28, 2004
- 2
- 0
- 0
I've never worked on a carb before. My 66 has a Holley 600cfm, and I got some crap in the gas tank, and it wouldn't start. I drained gas out, put new in. I pulled the inlet cover off carb, and found inlet needle valve sticking. I shot it with carb cleaner, put it back together, and it fired, but fuel is leaking now.
What kind of gasket sealer should I use on the inlet bowl cover? What kind of Loctite is used on the screws? Should I replace the inlet valve? Is this a common parts store item?
Thanks
Thanks
