Well, the SF Connectors are in, but it isn't a good thing at this point. I have a vibration that'll vibrate your fillings out. It is really strange. When I'm on the gas, no vibration. However, as soon as I let off the car vibrates like crazy. The vibration doesn't change if I'm in neutral or the clutch is in. It appears at about 35mph+, and it sucks. Reving the motor-up does nothing, so my thought is that it is not in the motor or clutch. With the car in netural, the rear-end, driveshaft, and transmission gears are turning. Therefore, I guess it has to be in one of those. I find it hard to believe that the car, through the floorboards, would soak-up that much vibration. The only change I made was the addition of the SF connectors, which I know stiffens-up the car considerably.
Sooo.... What now? Anyone else experience a similar problem after installing the SFC's? My thoughts are to replace the drive-shaft with a FRPP aluminum driveshaft. They are supposed to be pretty well balanced. If it's not that, maybe the guys didn't get the back-lashing right when they changed my RE to 4.10's. Thoughts??
I had wood under there (front end was too low), but it broke sending me down on the front facia. It popped loose on the passenger side and cracked the damn paint. I got pissed and put it back in the garage. I guess I need to find a lower friggin trailer, or longer ramps. Either way, I'm not giong to get it done today and now I need to get the *&#ing front clip re-painted. I'm about to sell it and buy something else (not really, just pi$$ed)... Venting
