Home Alignment
  • Thread starter Thread starter LONN17
  • Start date Start date Oct 13, 2006
LONN17
135
Oceanport, NJ
Oct 13, 2006
  • Oct 13, 2006
I just got my car all back together and mounted my new '06 GT wheels and new tires. The car now needs to be lowered a bit so I plan to do the shelby drop.
In the meantime - next couple of weeks - I want to run the car around town to make sure everything is in good working order. The tires are wearing on the outside edge and I would like to correct this so I dont kill the new tires. What needs to be adjusted if the outside edge is wearing? Toe-in?
As soon as I lower the car I am going to have it aligned prefossionally.
Thanks,
Trevor
iskwezm
4,159
20
79
Rowland Heights,California
Oct 13, 2006
  • Oct 13, 2006
Could be towed in, see tread if its feathering) or positive camber(but not usually when its lowered).
LONN17
135
Oceanport, NJ
Oct 13, 2006
  • Oct 13, 2006
The car isnt lowered yet but will be in the near future which is why I want to do a home alignment instead of paying for 2. I'll prob only put about 1-200 miles on it before I lower it. Just got it back together this week and I am not just ready to render it useless again. (I havent driven the car since 2001 aside from a spin around the block when I put a much needed new clutch in last year and yesterdays open header run to the exhaust shop)
Here is a pic as it sits now...
http://s65.photobucket.com/albums/h...current=tide010.jpg&refPage=&imgAnch=imgAnch4
Trevor
LMan
1,246
Mom's basement
Oct 13, 2006
  • Oct 13, 2006
buy yerself a caster/camber gauge and go to it!
[tomlasorda] "It's your duty, Judy!" [/tomlasorda]
19stang66
689
  • Oct 13, 2006
You got a sweet fastback Lonn! I love the color and wheels
J
John Z
581
Morgantown WV
Oct 13, 2006
  • Oct 13, 2006
Google for diy alignment yields many articles, such as
http://www.negative-camber.org/jam149/technical/alignment.html
Relatively simple equipment and once you have it and practice you will have more confidence than taking the mustang to a shop where the kid doing the alignment never before saw a car that uses shims for adjusting camber.
Good luck
brianj5600
1,964
Middle TN
Oct 14, 2006
  • Oct 14, 2006
Toe causes the most tire wear is it is off. It can be measured easily with 2 straight edges and a tape measure. I used 2 wood blocks and 2 levels. Set the straight edges on blocks about 4 or 5 inches tall and bungy them to a spoke on the wheel. Measure and adjust.
LONN17
135
Oceanport, NJ
Oct 14, 2006
  • Oct 14, 2006
Thanks for the info guys - I'll give it a quick alignment today.
Trevor
  • AeroCoupe
  • Aug 2, 2026
AeroCoupe
Foxbody adjust alignment
  • Creomod
  • Jun 7, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 14, 2025
2000xp8
Am I crazy? Dad looking to buy 69 as daily
  • stonerCPA
  • Oct 14, 2026
1965 - 1973 Classic Mustangs -General/Talk- Oct 18, 2026
nickyb
2003 gt, clutch pedal stiffness.
  • 2003 mustang gt modded
  • Feb 15, 2026
1996 - 2004 SN95 Mustang -General/Talk- Apr 17, 2026
N
Vibration after new clutch
  • nipple_looker
  • Sep 20, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 26, 2026
fasterthangas
F
