Hood lifts
I've used a similar product for my stock hood and it worked great. Had to get rid of them when the fiberglass hood was installed. They were just too stiff to use with the lighter, aftermarket hood.
I have them on my stock hood. Perhaps the aftermarket hood he spoke of would not accomodate rivets. They are simple to install. Just measure twice and drill once. MRT has a new style that doesn't require drilling. I believe it uses existing hardware to mount their brackets.
We put some on last weekend on my buddys 90. he has an aftermarket (storman norman) hood, and right where they are supposed to attach to the hood, the fiberglass is reinforced. if you do put them on, and you go to order an aftermarket hood, look at the underside of the hood to make sure it is able to have screws ran thru it. he likes his for the added hood latch failure / hood not flying off factor. i on the other hand cannot use lifters because my glass hood doesnt have enough meat at the mounting points to put screws in it. lastly, if you put them on a glass hood, watch how you close it.. you dont want to put all the pressure on the nose of the hood. you want to have a hand on the front of the hood, and one on the side so you dont take the chance of it flexing and cracking your paint
You bring up points that I did not think of like on how you close it. If I do get a hood it will be from cevinies ( spelling )
I was able to attach the actuators to the hood without too much trouble. All that was required was fabricating a small bracket for each side of the hood to use as an attach point then using two part epoxy to secure it. Like I said in my original post though, the fiberglass hood was just too light to make it practical. It required a decent amount of effot to close the hood. Imagine having stiff actuators for your rear hatch then replacing the hatch with one that weighs just a third as much.
Thats what I was concerned about so I just went to the parts store and made my own. These ones came from a Toyota Corolla trunk. Just made my own brackets out of some aluminum angle.
