Well after driving a stock 100,000 mile 1994 bottom end mixed with a new upper end for the past 1,000 miles it has finally eaten up the oil rings and smokes like crazy at idle but runs great. Anyway...Im pulling the engine back out to replace the rings, and ditch those ****ty cast aluminum pistons and switched to forged. The cylinders have the perfect cross hatch pattern and no ridge and DONT NEED to be bored but I was thinking if Im going to pull it out I might go ahead an bore it .030 over. So now my debate is to use used stock 5.0 forged pistons standard bore with new rings / or / spend another $400 for the bore and bigger pistons and end up with a 306......How much more power will the 306 make over the 302 ??? I have no power adders but plan on adding juice or boost down the road. Also which rings are best for sealing and longevity????
