Hot Start Problems & Low Power
  • Thread starter Thread starter 89lxsc
  • Start date Start date Mar 7, 2007
89lxsc
  • Mar 7, 2007
My Supercharged '89 LX is having hot start problems and has loss it's power. These problems happened when I last changed my head gaskets. I had an intake missfire on initial start because of bad timiming and had this issue ever since. Idle used to be 18-19" now is 13-16". Recently the air temp and water temp sensors tripped an error. Both have ~10,000 mile on them and are ford parts. I did a compression test today and have 145-150 across the board.
Mod parts are:
T trim Vortech
80mm Vortech MAF in fender on 4" intake pipe
30# injectors
FMU
Vortech Fuel pressure regulator
Explorer GT40 style intake
GT40P heads
1:1.72 Roller Rockers
MSD 6A
T-Rex booster pump
Two stage water/alcohol injection
All new sensors
Everything else has 130K on it.
jrichker
StangNet's favorite TOOL
Mar 10, 2000
27,512
2,813
234
Dublin GA
Mar 7, 2007
  • Mar 7, 2007
Dump the codes and see what the computer says is wrong…Codes may be present in the computer even if the Check Engine light isn’t on.
Here's the link to dump the computer codes with only a jumper wire or paper clip and the check engine light, or test light or voltmeter. I’ve used it for years, and it works great.
See http://www.troublecodes.net/Ford/
OR
See http://www.mustangworks.com/articles/electronics/eec-iv_codes.html
IF your car is an 86-88 stang, you'll have to use the test lamp or voltmeter method. There is no functional check engine light on the 86-88's except possibly the Cali Mass Air cars.
For those who are intimidated by all the wires & connections, see http://www.actron.com/product_detail.php?pid=16153 for what a typical hand scanner looks like. Normal retail price is less than $30 or so at AutoZone or Wal-Mart.
Or for a nicer scanner see http://www.midwayautosupply.com/p-7208-equus-digital-ford-code-reader-3145.aspx– It has a 3 digit LCD display so that you don’t have to count flashes or beeps.. Cost is $30.
Fuel ‘88 GT Runs Rich Cold — Fixes Itself When I Unplug Sensors (ECT, MAF, O2, etc.)
  • Sufarry
  • Nov 6, 2025
Fox 5.0 Mustang Tech Nov 9, 2025
Mustang5L5
A
88 Foxbody Starts but Stalls When Warm Please Help
  • airforcerob
  • Apr 2, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Apr 4, 2025
Engine 1990 LX 5.0L EFI Mustang Fuel Management Problems - HELP!
  • 5.0LXStanger
  • May 25, 2025
  • 2 3
3K
Fox 5.0 Mustang Tech Jul 11, 2025
5.0LXStanger
SURGING IDLE / NO IDLE CHECKLIST FOR 1996–1998 MUSTANG GT (4.6L 2V) - Work In Progress
  • Noobz347
  • Aug 30, 2025
1996 - 2004 SN95 Mustang -General/Talk- Aug 30, 2025
Help with Heat soak/Hot Start
  • JDL5.0
  • Jul 2, 2023
  • Digital Self-tuning Forum
6K
Digital Self-tuning Forum Feb 20, 2024
from6to8
