How did you get your gauge wiring through the firewall?
oz
1,079
10
58
Plymouth, MI
Greetings,
I am about to route my mechanical oil pressure and water temperature gauges on my '69 and am trying to find a place to pass the water temp sending unit and the small oil pressure tube through on the firewall so that I don't have to drill a hole.
Can anyone tell me how they did theirs and suggest a hole to use to avoid cutting a new one?
Thanks!!!
go ahead
Go ahead and drill the hole, find a rubber gromet at the parts store and drill the correct size for it. I'd suggest a larger hole, because you will run other stuff through there later (trust me). Just be sure to find a safe spot.
Agreed x3
And that's good advice about putting in a larger grommet than needed, as you WILL need it eventually.
