HOW DO I BLOCK THIS OFF, GOOD IDEA?
DNA DOA
184
Scappoose
I got tired of waiting for the car lift to show up so I pulled the motor and trans on Sunday. I have decided to not use the "heater tube assembly" which connects to the front of the upper intake manifold and goes back to the firewall and attaches to the little small bendy black hoses that go to heater core.
I don't care if my summer daily driver/race car has heat or not. So how do I block off the hole in the upper intake and the one tube that comes out of the water pump that connected to the heater tube assembly?
Is this a good idea or am I making a big mistake? I have pics I will try to put up. I went to NAPA and got a brass plug for the top hole in the upper intake, I think this will work. Has anyone else come across this little mod?
Thanks,
Ben :flag:
The cap you seek is available at most parts stores in the " help " section. Help is the brand name. The package is red. If I was at the shop I could give you a part #. If you really want to be baller get the Edelbrock high flow pump. The holes are tapped so you can put a pipe plug in to block them off.
Those cap could also be found in the A/C ,Radiator asles,I believe they are call " Heater hose cap " or something along that line.
