I have searched and found numerous threads on what and how to perform a 5 lug conversion.
I understand the front, 94-95 spindles, with the spacer for ball joint. Great/Easy!
For the rear, I have a 4 lug disc out of a turbo coupe. It is wider (1.5 total) and It really limits my rim/tire choices. I am currently running a 17x9 cobra R with 255 and I am getting little ,but existant, tire rub on the outer edge of the tire. I have read you can replace the axles with axles out of SN95 and it will keep the stock (turbo coupe) width. This would convert to 5 lug, but it will still create whelel fitment problems.
Rather than going to a 245 and loose traction, I want to try and either go back to stock track width OR find a way to make sure the new 5 lug wheels I get have the correct dimensions to "tuck" back into the wheel well and let me run up to a 275 tire in the back for when I go to the track. I dont see the point in using a max 245 width drag radial when I could be using 275 and actually hook up. Also note the car has ford racing C springs and is NOT a full out drag car.
Basically, I just want to utilize my current rear end. If required, Im prepared to sell the 4lug 3.73 disc setup and go for a setup that will work for my application.
My plan was to run a bigger brake setup, and 03/04 17 cobra wheels, or Y2K's 18s
THANKS GUYS
THANKS GUYS
